Go to Post I'll wait for someone else to do it, then disagree with whatever they say. :p - Jcarbon [more]
Unread 16-01-2012, 01:45
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Stabilizing robot on bridge with gyro or accelerometer
Originally Posted by RoboMaster View Post
The sensor (gyro or accel) will tell us when we've driven far enough. The drivers themselves will control the robot until then, in my idea.
I suppose you could have it drive forward a certain distance, controlled by encoders, or time based, but that's tricky and tweaking it takes a long time and it may be too variable.
Thanks Matt, how sensitive is the accelerometer to vibration and motion? I assume this means that it gives back a noisy signal that's harder to make sense of? Will the bridge rocking back to level be any problem with this? We've never really used the accelerometer on a competition robot.
Yeah, the Kalman filter sounds nice. I've read a little bit about it and my first impression is that it's a little too advanced for most teams, including my team. But all the power to you if anyone could get it working with better results. That would be cool.
Honestly, if you look past the vocabulary and linear algebra (so just use single variables), Kalman Filters are not that bad.
