Go to Post If you think that teams would never bypass the rules or do something unsafe (intentional or unintentional), I suggest you spend a weekend as an inspector. Every bad scenario that you can think of, we have seen. - Al Skierkiewicz [more]
Unread 10-01-2012, 15:08
Ian McTavish Ian McTavish is offline
FRC #4152
Ian McTavish is an unknown quantity at this point
Any reason I can't use Visual Studio?
Hi, I've started a Rookie team and we're getting to work. For programming I'm most comfortable with C++ out of the available languages. At our school we use Visual Studio for our IDE. Is there any reason I can't use this for the competition (obviousely I need to set up the libraries).
Thanks for your help.
Unread 10-01-2012, 15:17
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Any reason I can't use Visual Studio?
First off, Welcome to FIRST and Chief Delphi. I hope you guys have fun this year.
The reason Wind River is given to teams instead of another IDE such as Visual Studio for FRC use is due to the fact of the downloader. You are going to need to use Wind River to download your code, and it has some very good examples built into the WPI Lib, which is what we use to code FRC Robots in C++.
You can, in theory, do your code development in another IDE and copy and paste the code into Wind River when you need to download (I use this method to move code between my home PC and one of our 2 development laptops).
Instructions for downloading code to the robot via the Wind River IDE is part of the Getting Started with the 2012 Control System PDF.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 10-01-2012, 21:15
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
The reason WindRiver C++ is required is due to the cRIO possessing a different processor than your computer. Visual C++ from microsoft can only compile (by default) for an intel processor, while the cRIO is freescale-based.
While I am not sure if microsoft makes a suitable crosscompiler, as long as you are using windows it will be less of a hassle to install WindRiver.
Unread 11-01-2012, 00:07
spacepenguine spacepenguine is offline
AKA: Ian Hartwig
spacepenguine is an unknown quantity at this point
As sjspry said, the reason that they push WindRiver is because it includes the VxWorks cross compiler. You can actually upload compiled software to the cRio through the ftp interface (many teams use this to upload text files with configuration data). As far as I know, Visual Studio can't do the cross compiling that is required for the different processor/WindRiver embedded linux on the cRio.
On another note, WindRiver is not bad as an ide. It's actually built on Eclipse.
2008-2011: #226 - The Hammerheads
Unread 11-01-2012, 01:07
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
If your team does any kind of code management, you can actually develop in any IDE you want and push that code onto your repository and build it on your "dedicated" machine. That is what we are doing this year.
Unread 11-01-2012, 03:26
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
VxWorks is the operating system on the cRIO-FRC. It does not run embedded Linux.
Unread 11-01-2012, 06:22
FRC #4152
This seems like a great solution - I really appreciate everyone's comments. It saved some trial and error time!
Unread 16-01-2012, 02:34
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
If your doing this I recommend starting the project in winriver, then editing the created files in VS. I used to have a procedure on how to make VS compile for ppc by having it run the winriver command line compile commands, but I can't find it. I will look some more and see if I find it. If you did this, and maybe write a plug in to ftp to the crio, then you could use VS to edit and compile but not debug.
