Go to Post Take it from a team that mastered tank treads and still hasn't built them in over a decade - it's not worth it. - Isaac501 [more]
Unread 16-01-2012, 03:01
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
How do I code for a more complex joystick?
Our team is using two Logitech Gamepad F310's for our drivers station this year. We did use one last year and I think that I instantiated it correctly then however, on occasion I had strange errors concerning which axis did what. I'm simply asking if there's a better way than
m_driveStick = new Joystick(1, 5, 8)
 * Where 1 is the USB port number, 5 is the number of axes,
 * and 8 is the number of buttons.
to create this Joystick object.
Also, as far as I can tell, the left and right triggers on this controller are simply + and - on the same axis.
For some reason this way just seems...overly complex but I can't seem to come up with a method to simplify it that doesn't appear to add other unnecessary complexity.
Unread 16-01-2012, 03:13
Re: How do I code for a more complex joystick?
I think that that game controller has a switch underneath that changes the way the triggers are mapped. Does switching it help?
Unread 16-01-2012, 03:39
AKA: Raa'Shaun H.
I'll have to check when I get my hands on it again tomorrow but I think that will explain our mysterious 'axes changing their indexing' issues. I had forgotten about that switch since the Logitech RumblePad 2 that I own and tend to use for at home testing doesn't have one. Thanks ^_^
Unread 16-01-2012, 14:57
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
Lightbulb Re: How do I code for a more complex joystick?
Hmm, haven't encountered that. On another note, would you like to get the rumble to rumble?
Unread 16-01-2012, 15:41
AKA: Raa'Shaun H.
Actually, yes I would. Since our team doesn't use controllers with vibration functions, it's been on the back burner but I would like to try it out for my testing controller ^_^
Last edited by CardcaptorRLH85 : 16-01-2012 at 15:41. Reason: I hit submit too quickly....
Unread 16-01-2012, 17:48
enrique's Avatar
Smile Re: How do I code for a more complex joystick?
I did the code back in 2010 and haven't touched it since. Let me test it then I'll send it over. It uses the output from the gyro, but I was thinking of using it this year with a piezio vibration sensor I saw online. I'll get back to you.
Unread 16-01-2012, 18:02
AKA: Raa'Shaun H.
Thanks, I'm doing more coding this year than last since I'm adjusting our code to fit the new Command Based Robot template since it seems like it'll be easier to update in the future than my current code so I don't have as much time for the projects like the vibration controller.
Unread 16-01-2012, 18:23
enrique's Avatar
Yea I hear you. I'm still contemplating if I'm doing that command stuff this year. Or during the summer while there is no gun to my head.
Unread 16-01-2012, 23:59
enrique's Avatar
Post Re: How do I code for a more complex joystick?
Here try this.
http://www.techtigers.com/ResourceFi.../EngXInput.rar
From the robot code I was using this to send the angle of the gyro:
float angle = 0;
angle = (m_HeadingGyro.GetAngle());
m_TechTigerDashBoard.AddCluster();
m_TechTigerDashBoard.AddDouble(angle);
m_TechTigerDashBoard.FinalizeCluster();
you will receive the heading in the dashboard and I would multiply it by a very high number to in a sense make the gyro super sensitive and in essence using the gyro as a bump sensor and shaking the joystick.
I made several dlls that used directx and what not. If the EngXInput.dll does not work on your joystick let me know and I will send the other ones. But if I remember correctly, this one worked with most joysticks.
Unread 17-01-2012, 00:37
AKA: Raa'Shaun H.
Here try this.
float angle = 0;
Thanks, I'll try this out when I get a chance to test our robot later today.
