Go to Post The flux capacitor should have been allowed under the flowchart as long as it met the single component maximum cost. I did check with Digikey and they no longer carry the line. - Al Skierkiewicz [more]
Unread 15-01-2012, 20:34
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Andy Mark Plaction Wheel Dimension Discrepancy!
Hello All!
Looking for some clarification. On the Andy Mark webpage the width of the 8" Plaction wheel is 1.54" Inches. I've downloaded the Inventor Model and it measures around 1.625". Of course I found this out after building my model and going crazy trying to figure out why a spacer was off! (drove me nuts)!! It was completely my fault for assuming the width of the wheel model would be the same as the listed width on the website.
Does anyone have an actual width (a measurement from an actual 8" wheel) or could Andy Mark (If he reads this) post clarification as to which is the correct dimension!
-Going crazy with constraints in New York!
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 16-01-2012, 03:58
JakeD's Avatar
JakeD JakeD is offline
FRC #0360 (The Revolution)
JakeD will become famous soon enoughJakeD will become famous soon enough
Re: Andy Mark Plaction Wheel Dimension Discrepancy!
I believe its simply a mistype. Looking at the actual part drawing the hub width is listed as 1.640 inches. I don't have a physical wheel to measure but I noticed this too doing some research into using 8" Plaction wheels this year.
Unread 16-01-2012, 08:48
coreyjon's Avatar
Flight Engineer
Thanks! After Looking at the Inventor File I thought it was more likely a website misprint but wanted to be sure.
Unread 16-01-2012, 08:57
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Call AndyMark.
Unread 16-01-2012, 09:44
coreyjon's Avatar
Flight Engineer
Just got off the Phone with AndyMark - The Inventor STEP file and the PDF CAD drawing showing 1.64" as the Width at the hub are correct - so for anyone else looking to use these - hopefully this helps. I'm sure they'll update the website with the correct dimension. Back to work!
