Go to Post The only thing more dangerous than a Programmer with a screwdriver is a Hardware Designer with the root password... - kmcclary [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 16-01-2012, 09:49
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Help with finding 6 inch pneumatic wheels with a plastic hub
Regardless of the wheel type we are planning to pull the bearings and press in a hub for hex shaft direct drive.
The 3 mph is only 4 fps so that will be a problem. Thanks for the catch!
You can't fix something that isn't broken... but you can always break things that aren't fixed!
