Go to Post Consider that the 12V from your robot isn't any different from the 12V from your car's cigarette lighter. (Err... sorry... that's "power port" these days, thank goodness.) - dtengineering [more]
Unread 15-01-2012, 23:23
Stagger007 Stagger007 is offline
FRC #4379
Stagger007 is an unknown quantity at this point
Help With Programing
Hello my team is a rookie team and its the first time we do FRC and we finally got the java image on the cRIO now were running ode that is directly copied from the java guide and its not running. Our code is as follows:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Servo;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
public class RobotTemplate extends SimpleRobot {
RobotDrive drive = new RobotDrive(1, 2);
Joystick leftStick = new Joystick(1);
Joystick rightStick = new Joystick(2);
* This function is called once each time the robot enters autonomous mode.
public void autonomous() {
for(int i =0; i < 4; i++){
drive.drive(0.5, 0.0);
Timer.delay(2.0);
drive.drive(0.0, 0.75);
Timer.delay(0.75);
drive.drive(0.0,0.0);
public void operatorControl() {
while (isOperatorControl() && isEnabled()){
drive.tankDrive(leftStick, rightStick);
Timer.delay(.005);
Unread 15-01-2012, 23:25
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Help With Programing
Is it not connecting to the computer or what?
BTW, I would not use the for loops. Remember the "action" is not done almost instantly, it takes time for a physical object to be actuated. I would also take out the delays.
Unread 15-01-2012, 23:34
youxinche95 youxinche95 is offline
AKA: Eugene Che
FRC #0649 (MSET)
youxinche95 is an unknown quantity at this point
It's great to see rookie teams dive into text based programming languages!
getWatchdog().feed()?
I think that's missing,
or did you not enable watchdog?
either way, the code looks fine other than that.
Unread 16-01-2012, 00:17
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Did you fix the db37 cable (the ribbon cable connecting the digital sidecar to the cRio) if not then the jaguars/victors will not work in ports 1 and 2. they will in ports 3 and 4 (we figured that out after a lot of testing)
here is the document on fixing the cable if it applies: http://www.usfirst.org/sites/default...structions.pdf
Unread 16-01-2012, 09:49
FRC #4379
i did not enable the watch do I'm not really sure what that does
Unread 16-01-2012, 10:48
gixxy's Avatar
Basically the watchdog is a guardian. When enabled you need to "feed()" it and keep it happy. However if your code goes into an infinite loop or something the code will not be able to "feed()" the watchdog and it will die, and dis-activate the motors and other components with it, so that the robot doesn't go wild and break itself or something else.
However if you did not enable the watchdog, you should be fine not putting the code in for it.
Unread 16-01-2012, 11:33
AKA: Brad
#0190 ( Gompei and the Herd)
I just copied your program and pasted it into a new project and ran it. Other than the motor ports not matching mine, it seemed to run some motors, at least in autonomous. I didn't have joysticks on the test platform.
Were you seeing no movement at all? If so, I'd look for other problems, like (as has been said) the cable to the digital breakout board, or something else.
You should verify that the driver station software is set up properly and that you see green "Communications" and "Robot Code" indicators and that your team number is set correctly.
Let us know after trying those things.
Brad
Brad Miller
Robotics Resource Center
Unread 16-01-2012, 11:59
AKA: Brad
Brad
That was stupid... you know the test system had some servos that happened to be on those channels and naturally they moved before the motor safety stuff caught it. Change your autonomous code to look like this:
        drive.setSafetyEnabled(false);   // this turns off motor safety
        for (int i = 0; i < 4; i++) {
            Timer.delay(2.0);
            drive.arcadeDrive(0.0, 0.75);  // this was a typo in the book
            Timer.delay(0.75);
        drive.drive(0.0, 0.0);
Brad
Brad Miller
