Go to Post I've learned that the measure of success isn't the money you make, the education you get, or the car you drive. Your success can only be measured in the amount of people in whose lives you've made a difference and the size of your heart. - Amanda Morrison [more]
Unread 16-01-2012, 13:03
bmxer51 bmxer51 is offline
FRC #2874
bmxer51 is an unknown quantity at this point
Possible Frame Design
ID:	11401 Possible frame design. Please critique.
Unread 16-01-2012, 13:05
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Re: Possible Frame Design
Only four CIMs are allowed in this year's game, you are using 8 in that design.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 16-01-2012, 13:09
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Looks heavy.
How will you be mounting bumpers?
How will you be tensioning chains?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 16-01-2012, 13:11
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Small wheel base might have north/south stability issues.
Also, 8 Cims are four too many. They could be replaced with a BB motor and CIM-U-Lator or omitted.
Unread 16-01-2012, 13:14
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Your wheel base is pretty short for a long robot and it will be pretty difficult to get your Center of Gravity low with the amount of barrier clearance you have there. This would probably be a pretty tippy robot.
However, the idea is very good. Personally, I would push the macanums further out to increase the the wheel base, lower the middle wheel a bit and exchange the outer wheels for tiny unpowered ones.
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 16-01-2012, 13:17
FRC #2874
I know only 4 cims are allowed. The CAD models just had two per toughbox so i just left them. I will take into account the small wheel base thanks for the input!
Unread 16-01-2012, 14:10
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
I'm very concerned by the structure. What is the grey material your using in the frame?
Unless it's a ridiculous material, I predict that you'll have problems with the sides bending in/out of the robot.
Unread 16-01-2012, 15:00
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
If you only plan on having 1 CIM in each I would closely consider the Toughbox Nano for reduced weight over the standard Toughbox.
Edit: on second thought, you might consider direct-driving your Mecanum wheels from nano Toughboxes.
Some spacers/bracing in between each side plate will go a long way towards chassis rigidity and strength. Something like this: http://www.mcmaster.com/#cadinlnord/91780a075/=fu19e2
Unread 16-01-2012, 14:25
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
Looks very heavy.
This year only 4 cims allowed and you have eight.
What is the purpose of having four mecanum wheel and six other wheels.
Team 696 2010-2013 Student
2014 2x Industrial Design Award Winners CVR and LAR
2013 Inland Empire Finalists -696 Circuitbreakers, 3476 Code Orange, and 4140 Wired
