Go to Post I feel there really is only one team, and the name of that team is FIRST. - [more]
Unread 16-01-2012, 12:32
Gatekeeper Gatekeeper is offline
FRC #4054
Gatekeeper is an unknown quantity at this point
Jaguars are blinking yellow
We are a new team this year and just ran into a problem. We just uploaded the java code onto the robot but when we power the whole robot up the jaguars simply blink yellow. We tried olding down the user control button, turning on the jaguars, the lights would blink red and green for 4 seconds and then they would go back to blinking yellow. Any idea on how we can fix the jaguars so that they stay a solid yellow?
Thanks in advance!
Unread 16-01-2012, 12:38
jutayo23 jutayo23 is offline
Systems Team
AKA: Justin Yost
FRC #1124 (The ÜberBots)
jutayo23 is on a distinguished road
Re: Jaguars are blinking yellow
The Jaguars will blink yellow when they don't receive a signal. There could be a few problems here.
Do you have all of them connected to a signal source (PWM or CAN)? Is your code set to give a signal on the correct channels? Did you enable the robot from the driver station?
Hope this helps!
Justin Yost
Systems Team
President
Unread 16-01-2012, 13:00
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
What exactly is the "user control" button you cite? If it's the calibration button on the Jaguars, then you're using it in the wrong method. Refer to the Jaguar intro manunal to understand what it does.
Regardless of configuration, if your code initializes the ports the Jaguars are connected to, then the Jaguars should turn solid yellow when you enable the robot.
If you're on PWM, make sure that a)the DS module is in slot 2, b)all three power lights on the DS are active, c)the DB37 has been fixed as per FIRST's directions and is properly connected, d)you are actually generating output signals on the PWM ports the Jaguars are connected to.
If you're on CAN, make sure that a)your serial-RS45 converter has been properly assembled, b)your cables are properly made, c)there is a terminator plug at the end of the system, d)you have configured each Jaguar's firmware, and e)you are using the correct CAN IDs.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 16-01-2012, 13:15
FRC #4054
I believe we are using PWM, that would be the brown, red, and orange cabled that hook up to them right?
AS well does this also initiate the Jaguars?
RobotDrive drive = new RobotDrive(1, 2);
We also have the Black Jaguars and the user button is on the right side of them, it is a small hole labeled with "USER"
Unread 16-01-2012, 13:27
Systems Team
AKA: Justin Yost
Sorry, I'm unable to help you with your code since our team uses LabVIEW, but from your description, it does sound like you're using PWM. Also, there shouldn't be a need to use the USER button on the jaguars. Holding down the button for 4 seconds will reset the Jaguars to the default factory state, which shouldn't be necessary. I would recommend checking all of the things that were mentioned before and see if any of those fix your problem.
Justin Yost
Systems Team
President
Unread 16-01-2012, 14:16
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
That isn't correct. Holding the button for 5 seconds will put the Jaguar in calibration mode.
To reset the Jaguar, you need to hold down the button while turning it on. You will see the Jaguar blink red and green as it turns on if you have reset it successfully. I would recommend resetting the Jaguar just in case you accidentally recalibrated it when previously pressing the button.
As stated before, slowly blinking yellow means the Jaguar is not receiving signal. Double check all of your PWM cables and make sure they are in the correct orientation. Look for labeling on your digital sidecar and raised lettering over the SERVO port on the Jaguar:
S: Signal (usually white or orange)
+: Power (usually red)
-: Ground (usually black or brown)
Once the wiring checks out the next thing to check would be the Enabled state of your robot. If the robot isn't enabled by your driver's station (the classmate PC) the cRIO will not send signals to the Jaguars.
Many helpful documents can be found at www.ti.com/jaguar, including the 2012 Jaguar FAQ. They may help save some time when troubleshooting problems.
-David
Unread 16-01-2012, 14:21
slijin's Avatar
Pockets
AKA: Samuel Lijin
Yes, those are the PWM cables. Do note that brown-red-orange is not the only color coding scheme for PWM cables (white-red-black, yellow-red-black, and yellow-red-orange are also accepted standards). Keep in mind that the USER button is the calibration button, and for your purposes (or at least your current ones) you should not be playing with this button. Messinig up the calibration will have serious effects on motor control and hamper troubleshooting.
Furthermore, that line of code does not initialize the Jaguars, but rather creates a RobotDrive object that will allow you to do so. See this edited sample code from the Getting Started Guide to Java:
public class RobotTemplate extends SimpleRobot {
  Joystick leftStick = new Joystick(1);
  Joystick rightStick = new Joystick(2);
  public void operatorControl() {
     while (isOperatorControl() && isEnabled()) // loop during enabled teleop mode
      drive.tankDrive(leftStick, rightStick); // drive with the joysticks
      Timer.delay(0.005);
Emphasis mine. Of course, your code may be different, but keep in mind that simply creating drive does not generate a Jaguar signal, because you haven't created a signal source. The highlighted code above does that.
Unread 16-01-2012, 14:32
FRC #4054
Yes we have the java code all set up like that for operating. We had the jaguars off, held the user button on the jaguar and then turned the jaguar on to do a factor reset. So we reset the jaguars but they are still blinking yellow.
Systems Team
AKA: Justin Yost
@dyanoshak, sorry, I wasn't clear with my response. I left out powering on the Jaguar with the button pressed. The correct instructions on how to reset the Jaguar to factory default settings are:
  1. Power off the Jaguar.
  2. Press and hold the user button.
  3. Continue to hold down the user button and power up the Jaguar. The status LED will flash red and green.
  4. After about 4 seconds, the status LED will flash orange. Release the user button.
This can also be found on http://www.ti.com/mcu/docs/mcuorphan...ther+OT+jaguar
Justin Yost
Systems Team
President
Unread 16-01-2012, 14:57
AKA: David Yanoshak
Also, check to make sure that your ribbon cable was assembled correctly. See this document from the FIRST website: DB37 Ribbon Cable Assembly Rework Instructions
This was posted in the team updates, be sure to follow them!
Unread 16-01-2012, 15:01
FRC #4054
Yes the DB37 cable is fixed properly the jaguars still continue to blink yellow though. We just reimaged the cRIO and updated the java code with the sample project that slijin just posted, but still no fix the the jaguars
Unread 16-01-2012, 15:18
ColonelThrtyTwo's Avatar
ColonelThrtyTwo ColonelThrtyTwo is offline
FRC #3676
ColonelThrtyTwo is an unknown quantity at this point
I'm having this issue as well. We are using the cables that came with last year's robot (the circular ones, not the ribbon cables), so I don't think that's the issue.
Here's my test code, in Java:
// Image version: v43
public class RobotMain extends SimpleRobot
    Jaguar jag = new Jaguar(2,1); // Module 2, channel 1
    public void autonomous() {}
        System.out.println("Running...");
        while(isEnabled() && isOperatorControl())
            jag.set(1);
            Timer.delay(0.005);
        System.out.println("Stopping...");
        jag.set(0);
The robot prints Running and Stopping over the netconsole as it should, but the Jaguar doesn't receive any signals. The status light works, so I don't think that there is cRIO <-> Digital Sidecar communication issues. I've checked the wiring numerous times and don't see anything wrong with it; the white wire connects to the signal ports on both, red to voltage, black to ground. I can't think of anything else we could be doing wrong...
Unread 16-01-2012, 15:47
slijin's Avatar
Pockets
AKA: Samuel Lijin
At this point, what I would do is take a PWM signal generator and plug that straight into the Jaguar and see what happens then. I'll assume you don't have something like that on hand, however, so here are your options right now:
Swap out the Jaguar for something else that has been proven to work, such as a Victor or servo (in the case of the servo, remember to toss a jumper on the pins next to the PWM output). If it still doesn't work*, try switching the PWM channel, e.g. from 1 to 10, or if possible, use a channel that has been proven to work (in Colonel's case, try using an output from last year's DS). In my experience, there are rare occasions where, for some unknown reason, a DS output will not work, and using a different output channel will remedy the situation.
*By work, you should also ensure that the response varies with respect to input - i.e. for a Victor, turn green on forward and red on backwards.
If you have a multimeter available, measure the voltage (DCv) across the black and red pins (center and darkest color) at the Jaguar's end of the PWM; the reading should be +-5V (the reading should only be negative if you're reading voltage backwards).
Another approach you could attempt is setting up the serial-RS45 connector and attempting to configure the Jaguars themselves. If this fails (assuming you've done the process correctly) - you'll be able to tell if some Jaguars respond and others don't, or if you've followed every step to the letter and none of them respond - then it's a possibility that your Jaguars themselves are bad, in which case you'll need a replacement.
In short, what you want to do is isolate the problem by removing each and every variable from the problem - use stuff that you know works, so that it becomes a controlled variable.
Unread 16-01-2012, 16:16
AKA: David Yanoshak
What is the point of this measurement?
The center power pin is not used by the Jag, is it?
Correct, the Jaguar doesn't use the center power pin. I believe the Victor doesn't either since they both have the same scheme for the servo input.
Unread 16-01-2012, 16:26
Are you sure about this? I think you will only have a voltage on the center pin if you install the jumper on the digital sidecar.
