Go to Post You don't have to beat stronger teams to get better... to get better is to be forced to push the envelope against stronger teams. - Shankar M [more]
Unread 16-01-2012, 13:27
jutayo23 jutayo23 is offline
Systems Team
AKA: Justin Yost
FRC #1124 (The ÜberBots)
jutayo23 is on a distinguished road
Re: Jaguars are blinking yellow
Sorry, I'm unable to help you with your code since our team uses LabVIEW, but from your description, it does sound like you're using PWM. Also, there shouldn't be a need to use the USER button on the jaguars. Holding down the button for 4 seconds will reset the Jaguars to the default factory state, which shouldn't be necessary. I would recommend checking all of the things that were mentioned before and see if any of those fix your problem.
Justin Yost
Systems Team
President
