Re: Can not connect to Real-Time target
yes, yes, and yes I cant even ping the thing anymore, is the a way to reset the ip on it , there might be a chance we can save it.
Make sure Windows Firewall is turned off.
It was working fine, i could talk to it, image it and ping it, all of a sudden, it just stopped talking to me, I am suspecting a bad image, I was changing back and forth from Java to LabVIEW. Could I send it in and get it formatted at NI?
You can format the cRIO yourself using the FRC cRIO Imaging Tool. It should be on your desktop after you install Labview
If I'm not mistaken you can reimage the c-rio using the imaging tool from labview. Our team ram into a problem were we had to turn off the wireless card and firewall to get it to image correctly.
Well i cant even ping it, ive turned off all other network connections and it sill wont respond to pings and the imaging tool wont find it
#7
If you put it in safe mode, can the imaging tool see it?
