Go to Post At this point (after shipping the robot), I'm really looking forward to doing laundry, eating a square meal, and getting to bed at a reasonable hour. - Emily Pease [more]
Unread 16-01-2012, 14:06
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Re: Shooter Lag
Also remember that the available voltage will not always be 12V and will vary depending on your battery condition and how much power the rest of the robot is drawing.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 16-01-2012, 14:14
PriyankP's Avatar
PriyankP PriyankP is offline
FRC #0188 (Woburn Robotics)
PriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud of
Question Re: Shooter Lag
I think the best way to go at this problem is by combining the efforts of both the mechanical and the programming sub teams. If a shooter was designed in way such that only 85% - 90% of its power will ever be needed, then you could shoot your first ball at the "full" speed (say it's 85%) then second shot could be shot immediately by changing the shooter speed via programming to 90% and so on...
I would imagine that due to the loss of momentum, running at 90% would be similar to running at 85% when the time between two successive shots is small. Yes?
Champs Schedule Highlighter App [CD Thread]
#### XYZ Regional Finalists
Unread 16-01-2012, 14:17
Re: Shooter Lag
That was the intent of the bolded portions below:
2) The motor voltage required to hold that speed is sufficiently less than 12 volts...
#2 is so that your closed-loop speed controller has some "headroom" to apply more power (increase the applied voltage) to get the wheel back up to speed quickly
Unread 16-01-2012, 14:24
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: Shooter Lag
Best bet would be to delay the balls till the motor hit your ideal speed and your aim angle is correct. If you fire up 3 rapid balls that had the aim angle/motor speed off you have wasted 3 balls. Take a shot and see if it goes in then take another.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
