Go to Post Sometimes we over react to things, and thats where a PM can clear a bunch of confusion. - mechanicalbrain [more]
Unread 16-01-2012, 16:28
Moo's Avatar
Moo Moo is offline
FRC #3504
Moo is an unknown quantity at this point
Gyro/Acclerometer Wiring
Does anybody know how to wire/hookup a gyro sensor and/or the accelrometer? I have searched around but I could not find any helpful links that explained it in detail.
Unread 16-01-2012, 16:32
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Gyro/Acclerometer Wiring
Check out the KoP sensors page here;
http://www.usfirst.org/roboticsprogr...-parts-sensors
This should give you a somewhat accurate description, http://www.usfirst.org/sites/default...meter-Gyro.pdf
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 16-01-2012, 22:26
IrksomeZeus IrksomeZeus is offline
Electrical Team Leader
AKA: Austin Yates
FRC #3003 (Tan(x))
Team Role: Electrical
IrksomeZeus is an unknown quantity at this point
this was the most helpful for our team last year and everything worked as planned
Unread 16-01-2012, 23:00
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
If you open the Gyro/Accelerometer example in LabView, there is an extremely comprehensive wiring diagram.
Unread 16-01-2012, 23:11
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
I'll have to take a look at this... I haven't programmed with labview much in the past but it is the language our team is going with this year!
Unread 18-01-2012, 16:31
Team 3705's Avatar
Team 3705 Team 3705 is offline
FRC #3705
Team 3705 is an unknown quantity at this point
Is there a wiring diagram of the gryo/accelerometer to the digital sidecar? Because the data sheets was not very helpful...
Unread 18-01-2012, 22:31
CRLS97 CRLS97 is offline
FRC #0097
CRLS97 is an unknown quantity at this point
Hey guys I'm a programmer from team 97, Bionic Beef.
I have the wiring set up for the gyro and it gives feedback, however as I rotate it, I know it's not accurate. Rotating it 90 degrees only shows a ~45 degree change in what it reads and I tried adjusting the Volts/degree settings but no luck with that.
Also, with the accelerometer example provided with LabVIEW, after wiring it correctly (and I tried both interfaces), I get no feedback at all.
Apologies if this is the wrong thread to post this in :x
Unread 18-01-2012, 22:32
FRC #0097
Take a look at the FRC LabVIEW examples. You can find the appropriate project for the gyro / accelerometer and it even has a detailed picture of the wiring .
Unread 19-01-2012, 00:16
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
The wiring diagrams indicate what pins correspond to what. If you actually take a look at the DS, you'll notice that the 3 pins are labeled signal, 5V, and GND - which correspond to rate, PWR, and GND (or whatever the labels are) on the gyro and accelerometer.
CRL, have you made sure your DB37 is properly setup as per FIRST's directions? If that's not the problem, then you may want to go through your code and ensure data is being parsed properly (I know Java has had issues with this, I don't know about LabVIEW).
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
