Go to Post We do not pursue awards, we pursue greatness and the awards follow. - Sunshine [more]
Unread 16-01-2012, 16:46
ColonelThrtyTwo's Avatar
ColonelThrtyTwo ColonelThrtyTwo is offline
FRC #3676
ColonelThrtyTwo is an unknown quantity at this point
Re: Jaguars are blinking yellow
Thanks for the feedback.
I've tried moving the Jag from channel one to channel five, with no luck. I've also replaced the Jag with a Victor and the digital sidecar with a brand new one as well as the one we used on our last years robot, with no results. The voltage between the power and ground pins was zero in all of our tests. I don't have a PWM generator or a serial cable.
Another thing: our driver station says that the battery voltage is zero volts. Don't know if that has anything to do with it or not. Don't have a cable to our analog breakout yet.
Unread 16-01-2012, 16:50
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Originally Posted by Joe Ross View Post
Are you sure about this? I think you will only have a voltage on the center pin if you install the jumper on the digital sidecar.
I had always been under the impression that the jumper served some other purpose, but I distinctly recall measuring voltage when troubleshooting outputs my freshman year, though I could be mistaken. I'll be sure to confirm when I go into the lab tomorrow.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 16-01-2012, 17:01
slijin's Avatar
Pockets
AKA: Samuel Lijin
If the system on last year's robot is fully functional, prop it up on bricks, switch one of the motor controllers out for the Jag in question, and try to run it. If this fails, then it's almost definitely the Jag.
You don't need a serial cable to tether to the Jaguar, just a computer with a serial port (or a USB-to-serial converter). The 1st item on the 10th page (listed as the DB9/RJ12 converter, although I believe assembly is required) of the KoP checklist and a cable to connect to the Jag is all you need. Download the BDC-COMM interface from TI to do so.
Unread 16-01-2012, 19:51
Matt5893 Matt5893 is offline
FRC #2450 (Raider Bots)
Matt5893 is an unknown quantity at this point
We had this same issue, and I don't know if someone on the thread already said this, but make sure the inputs for the cRIO are in the correct slots
slot 1: analog
slot 2: digital
slot 3: solenoid
Once put it in slot 2 the jaguars were responding. Hope this helps!
Unread 17-01-2012, 11:18
Two silly questions, but I haven't seen them answered yet:
1) Do you have power to the Digital Sidecar? Make sure the BATT, +5V, and +6V LEDs are all lit.
2) Have you enabled the robot from the Driver Station as suggested in the very first response? Only after the robot has been enabled will the Jaguars be receiving a PWM signal and stop their flashing.
Not-so-silly question: What is the Robot Signal Light doing? Either the big amber light plugged in to the RSL pins on the Digital Sidecar, or the little green LED next to those pins. If it's off, there's a wiring issue, most likely either power or cabling to the cRIO DIO module. If it's blinking quickly, the robot has not established communication with the Driver Station. If it's blinking slowly, the robot is communicating but disabled. When the robot is enabled, it will be on steady with a very brief flicker off every second or two.
Unread 17-01-2012, 16:42
FRC #3676
Yes.
Yes.
It is acting normally, in that it is slowly flashing when disabled and mostly on when enabled.
slot 1: analog
slot 2: digital
slot 3: solenoid
Yea, it's in slot 2. The imaging tool bugged us about this, so we re-ordered the modules and all of them should be in the correct positions.
Unread 17-01-2012, 22:40
Here's my test code, in Java:
    Jaguar jag = new Jaguar(2,1); // Module 2, channel 1
...I can't think of anything else we could be doing wrong...
And now I see it. This year, the module numbers don't represent which slot the module is installed in. The first analog module is #1, and the first digital module is #1, and the first solenoid module is #1. You're telling the code to control something on the second digital module, which is probably not what you want it to do.
Unread 18-01-2012, 00:10
Roceres Roceres is offline
FRC #1572 (HammerHeads)
Roceres is an unknown quantity at this point
I am having a similar issue, but I am using Labview - there's a yellow light on Jaguar and putting a meter on the signal pin there seems to be no pwm signal. To test the motors and the Jaguar I ran one of the FRC examples provided in the help menu. It looks like everything is connected properly; I have also fixed my DB37 cable. I have not connected the Robot Signal light and not sure how that plays a role.
To eliminate the Jaguar as an issue, we connected up a simple servo to the side-car and ran the simple Labview Servo example - we got the same results. It seems we are getting no PWM signal from the digital side car.
Unread 18-01-2012, 00:17
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Originally Posted by Roceres View Post
Besides following all the troubleshooting steps in this thread, make sure that in LabView you are referencing the Digital Module #1. Module != Slot.
The Robot Signal Light (or RSL) is a useful tool for troubleshooting. As Alan stated earlier, check to make sure the RSL itself (when installed) or the LED's on the Digital SideCar are blinking correctly as referenced in his comment.
Unread 18-01-2012, 16:50
I will look at the RSL this weekend when our team meets. This is the Blink Pattern I found from a post from last year. Is this correct?
* Fast Blink = cRIO not communicating with Driver Station
* Slow Blink = disabled
* Short on/long-off Blink = either low battery or no code & disabled
* Long on/short off blink = Teleop mode
* Solid on = Autonomous mode
In addition, is it necessary to have the driver station operating? We haven't installed it yet and thought it was unnecessary if we weren't running the entire robot, just the simple servo or motor examples provided. If we need the driver station, are the disable/enable buttons on the driver station display disabling the PWMs somehow through the digital sidecar? That could explain our problem.
Unread 18-01-2012, 17:01
FRC #3676
Ah thanks for that, this solved it.
Unread 18-01-2012, 20:27
Yes it is necessary to use the driver station and enable. All outputs are disabled unless the driver station is communicating with the robot and enabled.
