Go to Post steve, don't hurt me - Alex Cormier [more]
Unread 16-01-2012, 17:02
kylevedder kylevedder is offline
Programmer
AKA: Kyle Vedder
FRC #0467 (Shrewsbury Colonials)
kylevedder is an unknown quantity at this point
Trouble reading Kinect values from robot
Hello,
We set up our robot and kinect recently and have gotten the kinect working on the driver station. The kinect server runs properly and the skeletons display under the Kinect Skeleton area of the dashboard.
However, we're unable to read any of this data from the robot. We're using WPIlib and java, and we started to test with the WPIlib KinectStickExample. This results in the printout "Bad Retval: 3" and all the read values are zeroes. We looked into the cause of this printout, and it's the FRCControl getDynamicControlData method. The API for this method says that the returned value should be 0, 1, or 2, but we couldn't find what 3 meant.
Other information... Trying to access the skeleton data from the Kinect class also resulted in all zeroes. We tried performing the gestures in front of the kinect but still received zeroes. The firewall on the driverstation computer is disabled and the kinect server is running. The driverstation and kinect drivers are all up to date.
Thanks for any help.
Unread 16-01-2012, 19:16
Re: Trouble reading Kinect values from robot
During the beta test, it was stated that this value means the robot isn't receiving the kinect data.
What is your network configuration? What kind of driver station computer are you using?
Unread 19-01-2012, 16:38
Edlinger467 Edlinger467 is offline
FRC #0467
Edlinger467 is an unknown quantity at this point
Our driverstation is an HP mini. And we are using LAN Realtek PCIe FE Family Controller. The IP address is 10.4.675, the subnet mask is 255.255.255.0, and the default gateway is blank. We appreciate the help.
Unread 21-01-2012, 15:33
mryfrmr's Avatar
mryfrmr mryfrmr is offline
AKA: Mary Farmer
FRC #0191 (XCATS)
mryfrmr is an unknown quantity at this point
We are also seeing the same behavior. The getY() method on the KinectStick continually returns 0 even though in the driver station we see that the skeleton is getting Y values. We are using java, and a Dell windows 7 driver station. Everything else is working well, camera, drives, normal joysticks etc.
Unread 21-01-2012, 23:23
uofifox uofifox is offline
FRC #2202
uofifox is an unknown quantity at this point
We are also having issues with the kinect. We are getting the skeleton and we're using C++. We've setup the server and run the debug for the server. Everything seems to work fine, but the robot is not getting values from the kinect.
It all seems to work fine except that the information isn't being sent to the robot. We've even tried to use the kinect object to just get if there is 1 person in the field of view, and we know that something isn't right because the ds is showing data.
Unread 23-01-2012, 17:43
Lapuz.geek Lapuz.geek is offline
AKA: James Lapuz
FRC #0467
Lapuz.geek is an unknown quantity at this point
An update from Team 467:
We tried using our old driverstation: a 2go pc running windows 7
it is running the same software as our newer dell
it worked and it did not give us any bad retval
we are currently trying to find a difference between the two systems
Unread 23-01-2012, 20:23
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
I thought it was said that finding the "joystick" values had not yet been implemented and that the teams would have to do so on their own?
Unread 24-01-2012, 08:00
Try installing Visual Studio C# (the Classmate has that).
There may be some required dependencies.
Unread 24-01-2012, 16:27
McInally467 McInally467 is offline
FRC #0467
McInally467 is an unknown quantity at this point
We have installed Visual C# to no avail.
Unread 24-01-2012, 17:14
RahatAhmed RahatAhmed is offline
FRC #4300 (The Lion Kings)
RahatAhmed is an unknown quantity at this point
Our team is having this problem, too, but we're using LabVIEW. We're using the Classmate, so it should have visual C# on it. The driver station sees everything fine, but no information reaches the robot.
Unread 26-01-2012, 11:16
Okay, FIRST thinks that the issue is due to a conflict with the missing Cypress IO board.
Here are some temporary solutions to try.
Please, report back if this helps or fails.
  • See if plugging your Cypress board USB in makes it all better.
or
  • Go to the Driver Station I/O tab, click Configure and change it to Compatible mode to see if that makes the Kinect data work.
Unread 26-01-2012, 18:24
FRC #0467
Smile Re: Trouble reading Kinect values from robot
Hallelujah!! Changing it to compatible mode worked. Thank you for solving our week long problem. Much appreciated.
Unread 26-01-2012, 20:01
AKA: James Lapuz
FRC #0467
The change to compatibility mode gave us access to the getY() method from the class KinectStick but not the getX() method
Unread 26-01-2012, 20:08
As detailed in the Getting Started with the Microsoft Kinect for FRC document, there is no gesture mapped to the X-axis in the FRC Kinect Server. If you want something on this axis, you will have to edit the Kinect Server C# code.
Unread 28-01-2012, 22:18
mryfrmr's Avatar
AKA: Mary Farmer
FRC #0191 (XCATS)
This worked for us too, we now see getY. Thank you!
I am here: http://maps.google.com/maps?ll=43.264436,-77.617103
