Go to Post Ah, to be a teenager and know everything again. - Alan Anderson [more]
Unread 12-01-2012, 18:33
instantcake's Avatar
instantcake instantcake is offline
AKA: Hunter Werlla
FRC #3847 (Spectrum)
Team Role: Operator
instantcake will become famous soon enoughinstantcake will become famous soon enough
smartdashboard
our team is attempting to use smartdashboard for PID but it will not even connect to our robot. any examples of using smartdashboard would also be appriciated.
Unread 16-01-2012, 18:42
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
Re: smartdashboard
When running the SmartDashboard, press view/add.../connection indicator,
It will be red if you have no connection and green if you do.
If it is actually red, then make sure you are on the same network as the robot and that your team number is set correctly (that can be changed by going to file/preferences and changing the team number).
Also, make sure that you have some reference to the SmartDashboard on your robot. If the robot doesn't try to use the SmartDashboard, then the SmartDashboard will not connect to the robot.
Unread 16-01-2012, 19:07
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Re: smartdashboard
on your driver station goto settings (i think) and change it to use remote dashboard
Unread 16-01-2012, 20:02
rudun's Avatar
rudun rudun is offline
FRC #0496 (Royals)
rudun is an unknown quantity at this point
Re: smartdashboard
It works for us without the remote dashboard enabled. However we can not get a feed from the camera to appear.
Unread 17-01-2012, 14:38
Programmer
AKA: Joe Grinstead
Re: smartdashboard
Make sure your camera allows for anonymous viewing. (It is a setting somewhere in the control panel).
Unread 17-01-2012, 16:38
Happy Birthday! Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
Re: smartdashboard
Yes, the camera has been set to allow anonymous viewing. We still have been unable to pull video. It funny because the rest of our dashboard works with no issue.
Unread 18-01-2012, 10:01
Programmer
AKA: Joe Grinstead
Re: smartdashboard
I don't know how the regular dashboard works, so I'll act as though you are talking about the SmartDashboard
So, for the SmartDashboard, once you have the camera set up on your robot with the right IP address and anonymous viewing, go to view/add.../ and select the camera.
A pink rectangle should appear that says "No Connection". You have to wait about 10 seconds before either the camera image appears or you know that there is no actual connection.
If there is still no connection after 10 seconds, then make sure your SmartDashboard is editable (view/editable) and double-click the pink square. There is the list of properties for the camera. Make sure that the IP address is set correctly.
Tell me if this works. We got it working with no hiccups over at team 3504...
Unread 18-01-2012, 17:55
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: smartdashboard
Make sure an account has been setup for the camera with "FRC" as the user and "FRC" as the password.
Unread 19-01-2012, 22:11
Re: smartdashboard
Yes, all that has been done. We are able to get video when we use default dashboard. Is there any good resource for the Smart Dashboard?
