Go to Post Lesson learned, /always/ have a pick list! - Lil' Lavery [more]
Unread 16-01-2012, 22:33
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
Gear down Motor or Gears?
So, to get around a 4:1 gear ratio, should I gear down with a gear box then run the chain system off of this with the same size sprockets, or should I gear down with the teeth on the sprockets in a 15 teeth to 60 teeth gear? Does it matter?
Unread 16-01-2012, 22:34
Andrew Lawrence
Posts: n/a
Re: Gear down Motor or Gears?
I don't think it matters. The purpose of a gearbox is to put all of that long, chaining through sprockets down to a smaller size.
Unread 16-01-2012, 22:36
FRC #4084
Ah okay thanks! I was worried with the CAD draw up that I would have to change it... ugh. lol So your saying I can achieve the same torque/RPM change with a 4:1 gear ratio in the sprockets as I would get from the gearbox?
Unread 16-01-2012, 22:37
pfreivald's Avatar
AKA: Patrick Freivald
You can. Efficiencies can vary dramatically from case to case.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 16-01-2012, 22:41
FRC #4084
What's that mean? Because I used the formula T = Ts - (N Ts ÷ Nf)
where T is the torque at the given rpm N, Ts is the stall torque, and Nf is the free rpm.
from http://www.gizmology.net/motors.htm
Unread 16-01-2012, 23:01
FRC #4084
What does that mean? Please help, because I don't understand*
edit: marked by asterisk
Unread 16-01-2012, 23:02
pfreivald's Avatar
It means that how you gear a system up or down can have very different efficiencies. Case-by-case analysis is the only way I know of for determining which is best.
Team 1551
I write books, too!
Unread 16-01-2012, 23:08
FRC #4084
Okay thanks! so basically, even a 4:1 gear down can somehow produce way less then calculated? by http://www.gizmology.net/motors.htm
Unread 16-01-2012, 23:12
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Some energy is lost to things like friction, heat and vibration in every stage of your gearing.
Spur gears and sprockets and chain are both very efficient if built properly -- as high as 98% or so. That means that 98% of the energy input on one end comes out the other.
Losses due to inefficiency occur at each stage of gearing -- so a system with two stages would be ( .98 * .98 ) efficient, for example.
--Madison--
...down at the Ozdust!
Unread 16-01-2012, 23:24
FRC #4084
Cool! and... disheartening.. but, with 96% effieciency, that still falls within our range which is about a 75% wiggle room.
