Go to Post I personally need all the limbs and eyeballs I currently have, and I assume other feel the same way. - bfk [more]
Unread 16-01-2012, 22:42
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Shooter wheels
Hi all,
Quick question. What would be the difference between using a 6inch or 8inch wheel for a single wheel shooter?
Besides weight [we plan to add some weight either ways].
I assume with the 6inch the balls will go a bit slower but would this be negligible?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 16-01-2012, 22:46
Andrew Lawrence
Posts: n/a
Re: Shooter wheels
The 6 unch wheels won't go "slower" so to speak, they will just have a smaller rotation than the larger 8 inch wheels. one rotation for the 8 inch wheel is larger than one rotation for the 6 inch wheel.
However, we've found some great success with 6 inch wheels, so try both. Do it right and you have a winning design.
Unread 16-01-2012, 22:52
Easton8's Avatar
Easton8 Easton8 is offline
AKA: Alex Hallberg
FRC #0008
Team Role: CAD
Easton8 is an unknown quantity at this point
Re: Shooter wheels
try both and see what works. I would recommend a 6 inch wheel, as it makes for a more compact shooter and the lighter weight means it takes less time to get back up to full speed between shots. But honestly just prototype both and see which one you prefer.
Unread 16-01-2012, 22:54
Mk.32's Avatar
AKA: Mark
Re: Shooter wheels
Those are the reasons why we are considering doing a 6inch wheel. Since the 8incher is a bit big.
Well I guess that is the best way to find out.
Unread 16-01-2012, 22:58
Easton8's Avatar
AKA: Alex Hallberg
FRC #0008
Team Role: CAD
Re: Shooter wheels
really the main reason not to use an 8 inch (in my opinion) is the size. Our team has a flywheel shooter with 4 inch AM performance wheels , which makes for a relatively compact shooter.
