Go to Post You enjoy your pepperoni pizza, I'll enjoy my cheese and peppers, and we can both agree that people that like pineapple on their pizza, while strange... are completely entitled to their opinions. - Andrew Schreiber [more]
Unread 16-01-2012, 23:30
hobbes20xxx hobbes20xxx is offline
AKA: Josh
FRC #2075 (Engima)
hobbes20xxx is an unknown quantity at this point
Two Cameras on robot?
Someone brought this up at team meeting, was wondering if it was allowed (or even possible) we want to use one kinect and another generic kitbot camera from years past (using labview, btw). Any reasons why we wouldnt want to do this, or why we would? All opinions are helpfull...
Unread 16-01-2012, 23:32
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
Re: Two Cameras on robot?
two cameras would be heavy
Unread 16-01-2012, 23:52
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
No, not really.
As for usefulness, yes, but probably not. You might end up having some, er, conflicts, if you try to send data from both to the dashboard or cRio at the same time. To remedy this, you might end up having to write your own networking code to fix this... but I'm not entirely sure about that if it will even work.
Now, assuming if it did work, and if you could get both images to the camera, and the network bandwidth allowed it, you could work wonders with the image processing (i.e. have the easiest time ever located the hoops distance with two cameras).
Thats a big if.
Bottom line: I'd say the benefits are great, but the difficulty is something that would make superman cringe.
Attending: MN Duluth Regional
Unread 17-01-2012, 00:41
beiju's Avatar
beiju beiju is offline
Growing Chief Delphi Addict
AKA: Will Pryor
FRC #3120 (RoboKnights)
beiju is an unknown quantity at this point
We're investigating doing this with our robot, and our programmer has found (theoretically, since we currently only have one camera) that we can plug one in to the cRIO for image processing and another into the router to display on the driver station. This is actually what we want, so we haven't investigated whether we can have two run image processing or not.
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Yes, the difficulty would make superman cringe. Have you read the "Using the Kinect on the robot" thread? Now add a normal robot camera in the mix and make sure it still works with bandwidth, etc. I'm not sure if it would work. Or if anyone has the time or experience.
What practical purpose are you thinking for this?
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 17-01-2012, 17:38
moogboy's Avatar
moogboy moogboy is offline
Wiggling With Experience
AKA: Bubba
FRC #3175
moogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the rough
my team considered this for a little bit but we abandoned the idea when we figured out that the Kinect requires considerable processing power to begin with, and if it were on the robot it would need its own separate processor to work at all. The practicality was also questioned, though I am unsure what the proposed use of the Kinect on the robot was.
Unread 17-01-2012, 19:39
AKA: Josh
FRC #2075 (Engima)
The practical function would be to have one camera focus down where we pick up balls and the next towards the hoops for tracking' sake
Unread 17-01-2012, 19:49
CarlosGJ CarlosGJ is offline
FRC #0418 (Purple Haze)
CarlosGJ is an unknown quantity at this point
My team is considering exactly the same thing. While it would be very difficult to put the Kinect on the robot, it is legal and (as far as I know) easy to put two kit IP cameras on.
Unread 17-01-2012, 19:52
Superman must be a wimp.
Last season I tested with three cameras, and the steps are to configure the cameras with unique IPs in the range of 11-20. Then open the source to the dashboard, duplicate the loop and display. It turns out that three streaming 640x480 full speed streams will bog down an old laptop, but the rest of the system was fine.
Greg Mckaskle
Unread 17-01-2012, 20:11
Chomantha1073's Avatar
Chomantha1073 Chomantha1073 is offline
FRC #1073
Chomantha1073 is an unknown quantity at this point
Last year we had two cameras on our robot: one on the chassis right above a large LED array to track the retroreflective tape and to see if a tube was in front of us when we were trying to hang, and one right behind our claw so we could see if we were aligned in autonomous and in teleop. We used the data from both of these cameras to watch matches from the robot's view after they were finished. When we were using the Classmate in 2010, we sometimes had issues with the video files making the computer slow down or crash, but when we switched to a more powerful laptop laptop, we were able to get through last year with no errors due to video files. Our software was only actively analyzing one camera for automonous hanging in teleop and the other was displayed on the driver station.
TL;DR: It's definitely possible to put two cameras on the robot. We've found it extremely helpful both when picking objects off of the floor and when manipulating the game pieces. We haven't tried putting a Kinect on the robot in sync with a regular camera, but we found that using two normal cameras is pretty straightforward.
Chomantha
(Cho and Samy)
Co-CEOs 1073
Unread 17-01-2012, 20:46
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'm no expert on the control system, but I know teams have used multiple cameras before. Even with the IFI control system. Definitely possible.
Unread 17-01-2012, 20:56
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Last time i check, there wasnt really a rule on how many cameras you could use. its just all communication has to go through the dlink. But I dont know if there is a rule against using a non wireless router connected to the dlink. that way you could use maybe like 6 cameras?
