Go to Post So we developed AI... it figured out the clue... already... made itself accordingly... and is currently walking to the peachtree regional if you find him ask him what the objectives are, we'd sure like to know! - Collmandoman [more]
Unread 16-01-2012, 23:18
Andrew Lawrence
Posts: n/a
Where to get 20 tooth sprockets for plaction wheels
Does anyone know where I can find 20 tooth sprockets that will fit on Andymark's 4 inch plaction wheels? I've looked for a while, but haven't found anything.
Thanks!
EDIT: It's #35
Unread 16-01-2012, 23:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Where to get 20 tooth sprockets for plaction wheels
I think you'll run into a problem with the chain contacting the hub, if you try to use that small of a sprocket. 22 is about as small as you can go, isn't it?
Unread 16-01-2012, 23:25
Andrew Lawrence
Posts: n/a
Really? Huh. That limits us a bit. Now the only other option is either more gearing down through sprockets, or getting a double sprocket larger than 15 teeth.
Unread 16-01-2012, 23:26
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
You could go ahead and use Mcmaster here: http://www.mcmaster.com/#roller-chain-sprockets/=fu73t2
You could take their CAD drawings and just edit the bore to fit your needs? sounds solid cuz they already have all the sprocket part done correctly and just export it to a machine shop
Unread 16-01-2012, 23:45
MrForbes's Avatar
AKA: Jim
It's kind of difficult to drill the standard robot 6 hole pattern into sprockets like that. Using sprockets from AndyMark or VexPro sure is handy.
Unread 16-01-2012, 23:47
FRC #4084
Yeah your right, but what do you think about having a machine shop making one? Just asking cuz we were hoping to do that, but is it possible? :/
Unread 16-01-2012, 23:50
Andrew Lawrence
Posts: n/a
Would it be viable to add an extra stage of gearing to the wheels? Like another stage between the gearbox and the wheels?
Unread 16-01-2012, 23:53
MrForbes's Avatar
AKA: Jim
What are you trying to do? make the robot go faster?
Unread 16-01-2012, 23:55
Andrew Lawrence
Posts: n/a
We are at 10.05 fps, and want to go around 12 fps.
Unread 16-01-2012, 23:56
MrForbes's Avatar
AKA: Jim
And you can't find a larger sprocket for the transmission?
Unread 17-01-2012, 00:00
Andrew Lawrence
Posts: n/a
We're using CIMple boxes, so that's 12 tooth pinion gears on CIMs going to a 56 tooth output gear which runs a 15 tooth double sprocket, going to "x" tooth sprockets on the wheels, where "x" currently is 22 or 24.
We can't change the gearbox itself, so we either need a larger double sprocket to mount on the CIMple box output shaft, or smaller sprockets to go on the 4" AM plaction wheels.
Unread 17-01-2012, 00:12
MrForbes's Avatar
AKA: Jim
And you're stuck on using 4" wheels?
Unread 17-01-2012, 00:15
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
or you could find 2 half inch bore sprockets with a key way (you could add that if you really had to) thin enough so that 2 would fit on the output shaft back to back.
Unread 17-01-2012, 00:16
Andrew Lawrence
Posts: n/a
Yes.
Andrew Lawrence
Posts: n/a
Hmm. That... Could work.
