Go to Post My team is graduating yet another class of great kids who will go into the world capable and focused. And after a decade and a half of FIRST robotics those memories are as treasured as any trophies. - Wayne C. [more]
Unread 16-01-2012, 23:52
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: Two Cameras on robot?
Originally Posted by tickspe15 View Post
two cameras would be heavy
No, not really.
As for usefulness, yes, but probably not. You might end up having some, er, conflicts, if you try to send data from both to the dashboard or cRio at the same time. To remedy this, you might end up having to write your own networking code to fix this... but I'm not entirely sure about that if it will even work.
Now, assuming if it did work, and if you could get both images to the camera, and the network bandwidth allowed it, you could work wonders with the image processing (i.e. have the easiest time ever located the hoops distance with two cameras).
Thats a big if.
Bottom line: I'd say the benefits are great, but the difficulty is something that would make superman cringe.
Attending: MN Duluth Regional
