Go to Post I blame FIRST for being the best thing that has happened to me. - vivek16 [more]
Unread 16-01-2012, 23:55
Andrew Lawrence
Posts: n/a
Re: Where to get 20 tooth sprockets for plaction wheels
Originally Posted by squirrel View Post
What are you trying to do? make the robot go faster?
We are at 10.05 fps, and want to go around 12 fps.
Unread 16-01-2012, 23:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
And you can't find a larger sprocket for the transmission?
Unread 17-01-2012, 00:00
Andrew Lawrence
Posts: n/a
We're using CIMple boxes, so that's 12 tooth pinion gears on CIMs going to a 56 tooth output gear which runs a 15 tooth double sprocket, going to "x" tooth sprockets on the wheels, where "x" currently is 22 or 24.
We can't change the gearbox itself, so we either need a larger double sprocket to mount on the CIMple box output shaft, or smaller sprockets to go on the 4" AM plaction wheels.
Unread 17-01-2012, 00:12
MrForbes's Avatar
AKA: Jim
And you're stuck on using 4" wheels?
Unread 17-01-2012, 00:16
Andrew Lawrence
Posts: n/a
Yes.
Unread 17-01-2012, 00:15
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Originally Posted by SuperNerd256 View Post
Really? Huh. That limits us a bit. Now the only other option is either more gearing down through sprockets, or getting a double sprocket larger than 15 teeth.
or you could find 2 half inch bore sprockets with a key way (you could add that if you really had to) thin enough so that 2 would fit on the output shaft back to back.
Andrew Lawrence
Posts: n/a
Hmm. That... Could work.
Unread 17-01-2012, 00:31
MrForbes's Avatar
AKA: Jim
look into using the AM sprocket hub that is designed to fit on a 1/2" shaft. Although you'd jump up to a 22 tooth sprocket
Unread 17-01-2012, 00:37
Andrew Lawrence
Posts: n/a
Thanks!
