Go to Post We are engineers after all so I say "Bring on the technology"!:yikes: - emersont49 [more]
Unread 17-01-2012, 00:01
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
Sprockets again?
I have another sprocket question here:
I've been looking around, and I need a sprocket I can mount directly onto the CIM motor. The CIM has a shaft diameter of .31 inches (8 mm) and I'm not sure where I can get a sprocket to fit that that has one of those spots to screw in a hex screw or whatever to hold the motor shaft.
Unread 17-01-2012, 00:04
Andrew Lawrence
Posts: n/a
Re: Sprockets again?
Please tell me you're not trying to direct drive your drive train... I shudder at the thought of it. I'm not sure if those kinds of sprockets are available. You may need to get an attachment to the CIM shaft to make it thicker.
Unread 17-01-2012, 00:05
FRC #4084
well I guess I could get a larger bore sprocket and insert my own cylinder to fill the gap while keeping the threading from the COTS sprocket, but I'de rather not :/
Unread 17-01-2012, 00:06
Andrew Lawrence
Posts: n/a
I'm not sprocket expert (as you can see from my various sprocket posts), so don't take my word as law, that;s just my thoughts on the subject.
Unread 17-01-2012, 00:07
FRC #4084
No way lol, That would be sweet though if you used the sprockets to gear down the motor 4:1 and run on super RPM with a light as hell bot
But in reality, this is powering our centripetal arm, and it would be nice to use the sprockets to gear down the motor instead of a gearbox to equal sized sprockets. I already have the second gear made (60 tooth with machined holes to mount on the arm spot done by our machine shop)
I do like the shaft diameter option though!! I'll look into that tomorrow!
Unread 17-01-2012, 00:09
Andrew Lawrence
Posts: n/a
Nice. You can try Andymark, if you haven't already, or McMaster Carr. They both have great hardware, and just about anything you'll need can be found at McMaster.
Unread 17-01-2012, 00:10
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Andymark has a hub for the 8mm shaft that you can attach a sprocket to.
http://www.andymark.com/product-p/am-0320.htm
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
FRC #4084
Yeah I've been surfing McMaster all day, and basically have a bot in the cart lol But they are just missing the sprocket size needed for direct connect to the CIM motor. I'm surfing andymark right now too
Unread 17-01-2012, 00:11
FRC #4084
YES THIS IS EXACTLY WHAT I NEEDED THANK YOU!
Unread 17-01-2012, 00:13
Mk.32's Avatar
AKA: Mark
Glad I could help.
Enjoy.
Unread 17-01-2012, 00:16
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
You can purchase some sprockets from AndyMark, but try bearing supply stores. Around here (Toronto Ontario Canada) I use "Canadian Bearing" "Toronto Bearing" "Oshawa Bearing" "BMI" etc. Also McMaster Carr. All these sources should be able to sell you sprockets with the correct bore or they will likely sell you a stock bore sprocket. In this case, you to chuck it in a lathe (a drill press can also be used in a pinch) and drill the center out of it to the right size of your shaft. Then you drill and tap a hole in the side of the sprocket to install an allen key. You can also buy cheap keyway broaches which with the help of an arbor press (or something really heavy, a car jack and some creativity) are used to cut internal keyways:
http://www.ebay.com/itm/18-NO-10-HSS...em518e50 9246
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 17-01-2012, 11:45
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
If you start with a sprocket with a 5/16" bore you can ream to 8mm and key to 2mm. I do this with 12 and 14 tooth gears for my gearboxes every year.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 17-01-2012, 11:54
Aren Siekmeier's Avatar
on walkabout
This hub is meant to be mounted onto a wheel with the typical 1.875" bolt pattern. Not saying that you couldn't also mount a sprocket to it (it would work perfectly fine), but you may want to mount a smaller one than the ones with that bolt pattern. Andymark has a few sprockets that are meant to be mounted on gearbox output shafts or motor shafts. See http://www.andymark.com/Sprockets-s/52.htm. Specifically for the CIM there are two #25 chain sprockets with the appropriate bore, as well as few more with a smaller (.25") bore that could be reamed out.
Otherwise, check out Mcmaster-Carr. They have a very large catalog that is relatively easy to work with and they are bound to have hub mount sprockets for the chain you want to use (#35, #25, #40, whatever) with the bore you are looking for.
Unread 17-01-2012, 15:01
FRC #4084
I think this is what I'll do, thanks for all the input guys! FIRST is amazing!
