Go to Post Welcome to FIRST, side effects may include...... - spears312 [more]
Unread 15-01-2012, 15:47
conwill345's Avatar
conwill345 conwill345 is offline
Student Programmer
AKA: Connor Willison
FRC #0708 (Hardwired Fusion)
conwill345 is an unknown quantity at this point
Downloading Java Code 2012 Problem
We've used java in previous years but can't seem to download code with this year's updates. We installed all the updates, re-imaged the crio and installed netbeans plugins, but the download stops at the following message:
Waiting to connect to OTA command server of 10.7.8.2:8001 for past 11s
The rest of the output is attached.
Unread 15-01-2012, 16:18
That Canadian That Canadian is offline
FRC #0346 (RoboHawks)
That Canadian is an unknown quantity at this point
Re: Downloading Java Code 2012 Problem
My team had this problem earlier as well. Make sure your wireless connection is disabled and then make sure your Ethernet connection is configured as follows. IP: 10.7.8.5 Subnet Mask: 255.255.255.0 Everything else left BLANK. Now these settings assume you are using the classmate to build code to the robot. If you're using a different computer make the IP 10.7.8.6 instead. If that doesn't work you can try changing the default gateway from blank to 10.7.8.2 (robots ip). If none of that works post back here.
Unread 15-01-2012, 16:19
Also how are you uploading the code? Directly attached to the cRIO or through a modem/router on the robot?
Unread 15-01-2012, 18:27
conwill345's Avatar
Student Programmer
We use a router.
IP addresses were set up as you said.
We ran the NI NetConsole utility for the cRIO. Then we tried to deploy code and got a socket bind error - already in use. After that, we closed netconsole and deployed again with no problems - go figure!
If anybody has an idea what happened, we'd like to know!
Unread 17-01-2012, 02:20
hzuo hzuo is offline
FRC #3274
hzuo is an unknown quantity at this point
Earlier today, I had this exact same problem (or an exact manifestation of a different problem), and after some googling, I found the solution here. Basically, all you have to do is to reset the cRIO.
