Go to Post You can lead a horse to water but you can't make it drink. Our job is to make the horse thirsty. - Andrew Schreiber [more]
  #46   Spotlight this post!
Unread 16-01-2012, 17:32
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: Official 2012 Motors Models and Specs Thread
Originally Posted by jason701802 View Post
I am asking about specs for the gearbox alone. Supposing it is attached to a more powerful motor, how much torque can the gearbox take before it breaks and how efficient is it?
We did a break test on the PG71 and broke it with an input of 88 ft-lbf of torque.
Andy
  #47   Spotlight this post!
Unread 16-01-2012, 21:16
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Can the PG71 handle side loads? For example, a sprocket mounted on the shaft?
  #48   Spotlight this post!
Unread 16-01-2012, 22:54
diviney diviney is offline
FRC #2377
diviney has a spectacular aura aboutdiviney has a spectacular aura aboutdiviney has a spectacular aura about
The FIRST specs are for the 775-18 at 12 volts
Ether:
The FIRST tables show 273W for the 775-18. Isn't that the 18V number? This motor (at 12V) is much less than what FIRST states (less than half of this, or 120W) isn't it? Not too much different than the 775-12 operating at 12V
-Tom
  #49   Spotlight this post!
Unread 16-01-2012, 23:28
Hi Tom,
See notes in red below:
Originally Posted by diviney View Post
Ether:
The FIRST tables show 273W for the 775-18. Correct Isn't that the 18V number? No. That's for the 775-18 operating at 12 volts. This motor (at 12V) is much less than what FIRST states (less than half of this, or 120W) isn't it? No. Not too much different than the 775-12 operating at 12V No, it's MUCH different.
-Tom
RS775-18 at 18 volts:
http://banebots.com/pc/MOTOR-BRUSH/M7-RS775-18
RS775-18 at 12 volts:
http://banebots.com/docs/M7-RS775-18-AT12V.pdf
  #50   Spotlight this post!
Unread 17-01-2012, 04:31
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Looks like they updated the Motor Data spread sheet. I still don't think it has all the correct FP part numbers as it doesn't match Team Update #2 but I think it's correct on the years at least.
http://www.usfirst.org/sites/default...torInfo3.1.pdf
  #51   Spotlight this post!
Unread 17-01-2012, 11:14
Yes, it can. There are two 10mm id ball bearings supporting the output shaft. The bearings are pressed into either side of the face plate, so that the outside to outside dimension of the bearing faces is 0.55".
Andy
  #52   Spotlight this post!
Unread 17-01-2012, 12:42
Aren Siekmeier's Avatar
on walkabout
[i]
Still looking for specs for the FP-9013.
As far as we can tell, the 9013 does not exist. No one has one, it cannot be purchased, and there are no specs on it anywhere. The only sources we have for this part number are from FIRST, I think its only a matter of time before FIRST finally purges any mistaken references to this mysterious part number. Until then, I'm not too worried about it since I don't have any 9013s that I want specs for. It would just be nice to know that they aren't jumbling specs for all the other motors too.
  #53   Spotlight this post!
Unread 17-01-2012, 13:36
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
We, as well as a number of other teams have received 9013's in our KOP. We have also found at least one in our bin of motors, indicating that they have come in a previous KOP as well, although it would have to be pre-2006 because there is a different FP listed in the KOP checklist for 2006 and later.
Jason
  #54   Spotlight this post!
Unread 17-01-2012, 14:35
Could I talk you into taking a close-up picture and posting it please?
Thanks.
  #55   Spotlight this post!
Unread 17-01-2012, 15:04
I'm not in town, but I will get someone else to take a picture at our meeting tonight. The model number is very hard to read as it is etched and not printed onto the casing. We actually didn't find an old 9013 motor, but we did find a flux ring from a 9013 motor, although I have been reminded of a possible non-KOP source for the old motor.
I shouldn't sat that many other teams have received a 9013 in their KOP, but I have read a couple posts where people indicated that they received a 9013 in their KOP.
Jason
  #56   Spotlight this post!
Unread 17-01-2012, 16:19
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Thanks.
Here they are, and yes these are from this years kit of parts. (I didn't even realize we had 9013s until a few minutes ago)
ID:	11424  Click image for larger version
ID:	11431  Click image for larger version
ID:	11432  Click image for larger version
ID:	11433  Click image for larger version
  #57   Spotlight this post!
Unread 17-01-2012, 16:53
Thank you.
I'm finally getting one or two Google hits on this.
http://www.worthpoint.com/worthopedi...motor-56954272
  #58   Spotlight this post!
Unread 17-01-2012, 22:29
PAR_WIG1350 posed better pictures than we have, so I'll leave it at that.
Jason
  #59   Spotlight this post!
Unread 19-01-2012, 09:17
PhantomPhyxer PhantomPhyxer is offline
FRC #2643
PhantomPhyxer is on a distinguished road
Does anyone have a table for 2012 Motor Specifications? From a know source.
Motor Name, Free Speed (RPM), Stall Torque (N*m), Stall Current (Amp), Free Current (Amp)
  #60   Spotlight this post!
Unread 19-01-2012, 09:18
http://www.usfirst.org/sites/default...torInfo4.1.pdf
Or you can use this.
