Go to Post Sometimes, you just have to beat something (someone?) into submission. Yes, you can use your head, but its a lot easier with a hammer. - Andy A. [more]
Unread 14-01-2012, 19:05
EagleBotBC EagleBotBC is offline
FRC #2838
EagleBotBC is an unknown quantity at this point
Multiple Joystick Help
I am trying to figure out tank drive for our robot and whenever I try to open a new joystick on Begin.vi it changes the USB port on the 1st joystick as well. I have tried changing the name of the joystick, but it changes both of them when I do. Please help me!
Unread 14-01-2012, 19:46
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Re: Multiple Joystick Help
what you have to do is open two under begin vi, with a different name for each. Under teleop, you use two get refnames (one for each).
Unread 15-01-2012, 00:08
It sounds like you are changing the the values on the front panel of the joystick open vi, rather then wiring a constant into the joystick open input in begin.vi.
Unread 15-01-2012, 14:26
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
All you need to do to configure tank drive is open teleop.vi, change out the Arcade drive block for Tank drive (WPI Library>Robot>Tank Drive), and wire in the second joystick.
Unread 16-01-2012, 10:48
waddell waddell is offline
FRC #4205 (RoboCubs)
waddell is an unknown quantity at this point
DominckC,
So, for a total noob with NO programming experience, I'm the mechanical coach, what would the diagrams look like?
I found the Tank Drive block.
Unread 16-01-2012, 21:55
Anyone awake?
Unread 16-01-2012, 22:27
Like this:
Some other examples are here
Unread 17-01-2012, 00:56
Thanks Mark,
If we get snowed in tomorrow I'll give it a try then.
Unread 17-01-2012, 01:00
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Quoted for emphasis. Sounds like the OP's problem.
Mark, your section for the Begin VI is missing a pair of joystick open and set joystick reference VIs.
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 17-01-2012, 08:02
That's because it's from a series of examples. A previous example describes the Joystick open.
I use the series for teaching and the students are expected to learn to apply prior examples in building block fashion to subsequent examples.
Also, for brevity's sake subsequent examples don't repeat all the prior examples. Otherwise it gets very unwieldy in later compound examples and loses the independent point each is trying to make.
It's a teaching style choice.
Unread 17-01-2012, 16:29
FRC #2838
My problem is in the begin.vi. When I open them the refnames change simultaneously, so that when I change one the other changes as well.
Unread 17-01-2012, 16:54
Did you create the new joystick from scratch or copy it somehow?
Do you know how to get the wirespool cursor when you hover over the name node, right-click and choose Create -> Constant?
Unread 17-01-2012, 17:05
FRC #2838
At first I was trying to copy and paste, but then once I created it from scratch they still seemed to be linked. I have tried Create -> Constant as well.
Unread 17-01-2012, 22:50
What exactly do you mean by "open them"? It might help to show us your code.
