Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Unread 17-01-2012, 08:40
Re: USB cRIO Module for Kinect
Originally Posted by soxfan269 View Post
So I pose two questions. 1) Is having the Kinect as a sensor a big advantage. 2) Is it worth $320 to make it easy to connect the Kinect.
I'll answer the question you should have asked first.
0) Is it even possible to do this?
The answer is no. The FPGA image required for FRC does not support the USB module.
