Go to Post I get in enough trouble mentoring one team. If I did five teams I'd be less one wife. - Koko Ed [more]
  #31   Spotlight this post!
Unread 16-01-2012, 02:28
Aren Siekmeier's Avatar
on walkabout
Re: pic: We've got balance, how bout' you?
Originally Posted by Kevin Sevcik View Post
I disagree. Adding weights in the right location is the best way to simulate the competition bridge.
Firstly, adding weight DOES make the bridge more stable and less sensitive. The CoM is the weighted average of the bridge's CoM and the batteries CoM. Heavier bridge means the batteries move the overall CoM less. I proved that to another mentor tonight with a scrap pie of plywood adding weight to the bridge and a battery barely balancing it. Pick up the plywood and down goes the bridge.
Secondly, the moment of inertia of the bridge could definitely matter to balancing and knock down mechanisms. A heavier bridge is going to have slower dynamics than a lighter bridge. It will accelerate and decelerate more slowly, which may affect dynamic balancing systems. Bungees add no mass, and thus leave a lighter, more lively bridge system. Similarly, lack of care in locating your added weights could leave you with a more sluggish bridge than you'd face in reality.
Long story short, there's no substitute for the real thing. If you can balance the super sensitive bridge, you'll likely only need a little tweaking at competition, but you should expect tweaking to be necessary.
I think we need some physics. All that we are given about the real competition bridge is the field drawings (from which we could glean a lot of things) and the "battery test," which I would argue is all that matters. You absolutely can get a wooden bridge to pass this test by playing with weight distribution, but adding weight to each end doesn't accomplish this. In fact, adding equal weight to each end does nothing. When the bridge tips around either of its hinges, you are lifting all the weight on one side of that hinge while letting all the weight on the other side down, by more or less equal amounts. The parts of the bridge OUTSIDE the two hinges cancel, because they are equal (sort of, in the team drawings they aren't really), and they are still equal if you are adding equal weights to each end. It's the weight BETWEEN the hinge points, and to some extent the hinging geometry itself, that affects the "tippiness." So by adding weight between the rock points, you are adding weight that must be lifted when the bridge tips, making it less sensitive. By taking away weight in the middle, you lift less weight to tip the bridge so it tips more easily and more sensitive. I didn't actually do any really involved analysis of this problem (taking into account things like the varying distance of each end from the hinge point, how the cg moves and the weight distribution changes when it tips because of the height of the cg, etc.) but I consider these to be mostly negligible so hopefully my rough approximation for a first pass analysis is good enough.
  #32   Spotlight this post!
Unread 16-01-2012, 15:15
ez4nick ez4nick is offline
FRC #1279
ez4nick is an unknown quantity at this point
was anyone able to successfully balance a bridge with the battery test without any modifications to the bridge??
  #33   Spotlight this post!
Unread 17-01-2012, 09:42
lerikson's Avatar
lerikson lerikson is offline
Dj Mother May i
AKA: Lukas
FRC #1270 (Red Dragons)
lerikson will become famous soon enough
Send a message via Yahoo to lerikson
Pretty impressive.
Official FRC Game Announcer & Master of Ceremonies for multiple events
  #34   Spotlight this post!
Unread 17-01-2012, 09:45
Jared Russell's Avatar
Taking a year (mostly) off
We were not. It takes adding (quite a bit) of weight or bungees to get it even in the same ballpark.
