Go to Post I know alot of the rookie teams were helped out alot this year. Do the same thing for the rookie Volunteers as well. - wilsonmw04 [more]
Unread 16-01-2012, 13:18
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
no communication
after reimaging the crio and dowanloading all the updates successfully , we just simply can not get a wireless communication , while it works perfectly when the crio is connected wirely to the computer , we're thinking that it could be a bridge problim so we are about to reset it and reconfigure it all over again , i mean what else could the problime be ??? still we are not sure it's gonna work ,, so if you have any other suggestions we'd be more than delighted to hear them .
TEAM 1946-Tamra
Unread 16-01-2012, 13:35
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
Re: no communication
yea if it works wired, then your wireless is off somewhere. I actually put the wireless AP on the robots when we are testing in the lab. Because then you can just have the classmate choose the ap from its internal wireless. It also, gives you a list of robots when you have several robots with APs.
Unread 16-01-2012, 15:57
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Make sure the wireless is turned on for your classmate.
Make sure you have connected to DLINK (View wireless connections, connect)
Make sure DLINK is in AP mode
Turn off Windows Firewall
Run Driver Station, make sure your team number is set correctly
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 17-01-2012, 11:47
yara92's Avatar
AKA: Mohamed
in fact when we ran the driver station update at the first time we forgot to turn off windows firewall , we reran it allover again after turning it off , could that be what caused us the communication problem ???
TEAM 1946-Tamra
Unread 17-01-2012, 14:53
yara92's Avatar
AKA: Mohamed
it worked eventualy, thank you guys ))
TEAM 1946-Tamra
