Go to Post When our arm "spontaneously combusted in the middle of the field", your team was the first to offer assistance to help fix it. - KTorak [more]
Unread 12-01-2012, 21:13
Cody Trey's Avatar
Cody Trey Cody Trey is offline
Programing = hard + fun
FRC #2582 (Panther Bots)
Cody Trey is an unknown quantity at this point
Send a message via Yahoo to Cody Trey
Exclamation Error: a timeout has been exceeded
the full errer reads: ERRER: A timeout has been exceeded: RobotDrive... Output not updated often enough. ...in Check() in C:/WindRiver/workspace/WPILib/MotorSafetyHelper.cpp at line 123
does any one know how to fix it. I feel like it might be something simple, but my brain is fried.
please help....
Love, Peace, and Robot Grease
Unread 12-01-2012, 21:20
AKA: Brad
#0190 ( Gompei and the Herd)
That usually means that the motors in your RobotDrive object aren't being refreshed often enough or the timeout on the motor safety is too short. Check that you don't have any long Wait function calls that would put a delay between motor speed updates.
Brad
Brad Miller
Robotics Resource Center
Cody Trey's Avatar
Re: Error: a timeout has been exceeded
the only wait a have if the wait(0.005) for the motor update
Forgot to include my code
here it is:
#include "WPILib.h"
* This is a demo program showing the use of the RobotBase class.
* The SimpleRobot class is the base of a robot application that will automatically call your
* Autonomous and OperatorControl methods at the right time as controlled by the switches on
* the driver station or the field controls.
class RobotDemo : public SimpleRobot
RobotDrive myRobot; // robot drive system
Joystick stick; // only joystick
Jaguar jag;
public:
RobotDemo(void):
myRobot(1, 3, 2, 10), // front left, rear left, front right, rear right
stick(1), //these must be initialized in the same order
jag(9)
myRobot.SetExpiration(0.1);
* Drive left & right motors for 2 seconds then stop
void Autonomous(void)
myRobot.SetSafetyEnabled(false);
myRobot.MecanumDrive_Cartesian(0.0, 0.5, 0.0, 0.0); // drive forwards half speed
Wait(2.0); // for 2 seconds
myRobot.MecanumDrive_Cartesian(0.0, 0.0, 0.5, 0.0); // spin robot
myRobot.MecanumDrive_Cartesian(0.0, 0.0, 0.0, 0.0); // stop robot
* Runs the motors with single stick holonomic steering.
* comment
void OperatorControl(void)
while (IsOperatorControl());
myRobot.SetSafetyEnabled(true);
myRobot.MecanumDrive_Cartesian(stick.GetX(), stick.GetY(), stick.GetTwist(), 0); // drive with arcade style (use right stick)
Wait(0.005); // wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
Unread 12-01-2012, 21:23
please help....
Are you seeing this error a time or two, or is it repeating in the window? Is the robot functioning?
Unread 12-01-2012, 21:27
Cody Trey's Avatar
it repeats over and over in the diagnostics messages box. it funtions in autonomous but not in teleop
Unread 12-01-2012, 21:29
Saw your code after I posted. You shouldn't have a semicolon after your while statement in teleop, your code is looping doing nothing.
Unread 16-01-2012, 23:59
makahn64 makahn64 is offline
FRC #0256
makahn64 is infamous around these partsmakahn64 is infamous around these partsmakahn64 is infamous around these partsmakahn64 is infamous around these partsmakahn64 is infamous around these partsmakahn64 is infamous around these parts
The above code looks fine to me...the brackets all balance and I do not see an out of place semicolon.
I am having the exact same problem, but only with the old CRIO. The new CRIO works fine. No idea what is causing it yet. Even happens with just the raw, unmodified, SimpleRobot template.
Unread 17-01-2012, 12:48
This line is definitely not fine
Unread 17-01-2012, 13:09
FRC #0256
You're right, didn't see the semi before the bracket.
Nonetheless, the problem seems to come from not turning off the robot safety. Worked for me.
Unread 17-01-2012, 13:54
petet4 petet4 is offline
AKA: Pete Thomas
FRC #0706 (Cyberhawks)
petet4 is on a distinguished road
Cody, your issue might be that the expiration time has not been set.
Use the motorsafty member GetExpiration() to see what the time is set too and the member SetExpiration(float timeout) to set a time.
See if this helps.
-pete
Unread 18-01-2012, 15:26
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
Red face Re: Error: a timeout has been exceeded
See if this helps.
-pete
Yes, the error suggests the code was run even with the semicolon problem, but it expired during that command. Starting to wonder if the command based stuff is that much better.
Unread 18-01-2012, 16:56
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
My team had this problem last night - we declared a robotdrive, but only used it some of the time. If the trigger was down, we drove the drive motor Jaguar instances directly by calling Jaguar::Set. We assume that the RobotDrive instance didn't like that IT wasn't getting called for a period of time, even though we were in fact updating the motors.
We fixed it by adjusting our direct-set code to run through RobotDrive instead.
It looks like this isn't the same as your problem since (aside from the semicolon after the while loop) your code always calling the RobotDrive functions.
Suggestion: Maybe try RobotDrive::TankDrive or RobotDrive::ArcadeDrive just to rule out it being a problem with the RobotDrive::MecanumDrive_Cartesian function?
