Go to Post "OMG Is that brandon?!?!?" "Lets go say hi" "No i'm scared" - Josh Hambright [more]
Unread 17-01-2012, 20:51
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Axis Pan+Tilt Servo issue?
Hello -
We've installed the Axis Pan and Tilt kit on one of our Axis cameras, but I'm having some issues controlling the servo's. I've written the two servo's into Begin.vi, Teleop.vi, and Finish.vi (all wired to Joystick 3), but they refuse to respond.
Am I going about this in the absolute wrong way?
Begin.vi -
Teleop.vi -
Finish.vi -
Thanks
Unread 17-01-2012, 22:22
Re: Axis Pan+Tilt Servo issue?
Servo Set Angle expects an angle (in degrees). The joystick Get axis are from -1 to 1, which isn't a very big range of angles.
Unread 17-01-2012, 22:28
FRC #0023 (PNTA)
Rookie Year: 1620
I looked under the example code. Seems the servo's have a 170 degree limit, whereas the joystick has a 360 degree range of motion. I guess that means a joystick is out as a controller. What else can I use to control the camera?
I could try putting Servo Set Angle with a numeric constant within a case structure and wiring it to a joystick button and seeing if that would work.
Unread 17-01-2012, 22:50
FRC #0023 (PNTA)
Rookie Year: 1620
Update - Here's what I threw together. I may edit the buttons once I get the joystick back in front of my face to see the button layout.
Currently, the code sets the servo's to their home or middle angle. From there, I can mount the camera and have 85 degrees of motion on both pan and tilt.
Later on, I'll add more case structures mapped to more/different buttons which move the camera to predefined angles. Good idea, or too much to do during teleop?
Unread 17-01-2012, 22:51
I added the output values for the joystick to my previous post, because I realized the documentation wasn't clear at all.
You can use a joystick to control a servo, you just need to use a (simple) equation to scale the joystick value to the range the servo expects.
Unread 17-01-2012, 23:06
FRC #0023 (PNTA)
Rookie Year: 1620
Oh, I see! I'll try to get both methods working (joystick and case structures) and see which one our drivers prefer. Will post my results tomorrow.
Thanks!
Unread 17-01-2012, 23:22
While you won't overload the cRIO doing that, it does take some time to program a whole bunch of cases.
Unread 17-01-2012, 23:27
FRC #0023 (PNTA)
Rookie Year: 1620
True. I might just end up figuring out the equation and running from there.
Unread 18-01-2012, 02:50
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Just to recap and correct the above comment:
The joysticks get function outputs a range of -1 to +1, floating point. So even though the joystick has a larger range of motion in degrees, it is scaled down by a factor of 127. It is then limited to within that range. (256 units)
Therefore you have to scale your joysticks between this range of 2 to a range of 170.
Mike B
Unread 18-01-2012, 20:08
FRC #0023 (PNTA)
Rookie Year: 1620
I've gotten it to work, thanks everyone for your help!
