Go to Post For fun, someone ought to spread out a bunch of petri dishes or something all over a regional and see what you bring home with you. Or not. - KathieK [more]
Unread 17-01-2012, 19:35
zkxs's Avatar
zkxs zkxs is offline
Java Programmer / Electronics
AKA: Michael
FRC #2004 (Thunderducks)
zkxs is an unknown quantity at this point
Re: Problem installed FRC Plugin on Netbeans
I checked, and the XP laptop that a NetBeans reinstall fixed had 4GB RAM.
Originally Posted by rudun
Deleting the sunspot folder and installing the plugins manually worked for me.
I tried a manual install first, and I can't find a sunspot folder. Do these plugins expect to be able to install to a shared directory? I'm not running Ubuntu as root, so NetBeans doesn't have privileges to write to shared directories.
Unread 17-01-2012, 21:02
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Okay, same problem... We are using a server with 3 gigs of Ram and Xeon processors, NOT the issue here. So I had issues with my personal laptop, but somehow it eventually installed... I tried both manual and the automatic update one. So it shows up as installed until I restart the IDE. Then it has no evidence that it even installed. Tried it 10 + times both manually and automatically... I know what Einstein said about repeating the same thing over and over again...
Unread 17-01-2012, 21:25
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
[SIZE = 1]FIXED[/size]
The plugins work with NetBeans 7.0.1, NOT 7.1... My personal laptop has 7.0.1 and we installed 7.0.1 on the server, it confirmed works.
Unread 18-01-2012, 18:24
Secretspy97 Secretspy97 is offline
FRC #1126
Secretspy97 is an unknown quantity at this point
We resolved our problem by installing the newest version of NetBeans and then installing the FRC plugins.
Unread 18-01-2012, 18:27
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
2 Windows xp 2gb ram
Windows xp 1gb ram
Ubuntu 10.10 with 3gb ram
Ubuntu 11.10 with 1gb ram
Windows 7 with 2gb ram
Windows Vista with 3gb ram
I have gotten all of these computers to run both netbeans and use the plugins with NetBeans 7.1.
I also installed Netbeans 7.0.1 portable on my flashdrive and have had it work at every computer I use it at.
http://portableapps.com/node/28772
