Go to Post Our robot attacked our programmer autonomously. - sanddrag [more]
Unread 17-01-2012, 12:57
Ido_Wolf's Avatar
Ido_Wolf Ido_Wolf is offline
LabVIEW Addict
AKA: Ido
FRC #2230 (General Angels)
Ido_Wolf is an unknown quantity at this point
Old cRIO not responding using 2012 code
Hello, we're using the old 8-Slot cRIO (9074). The cRIO has been reimaged to the 2012 image. When we try to deploy any sort of 2012 FRC code (using LabVIEW), it won't work - for example, Jaguars won't respond, we can't get image from the Axis Camera (model 206), etc.
We currently use the module no. 9403, we tried to connect it to every single slot in the cRIO and nothing responds. Is there any possible solution?
Unread 17-01-2012, 13:08
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Re: Old cRIO not responding using 2012 code
Try running the cRIO Imaging tool, and examine the picture of the cRIO shown (you should see red/white/green bars). Because of the new 4 slot cRIO, some things had to be moved around, including what modules can be plugged in to where. If you see red in the picture on the imaging tool, it means it needs to be moved. Just hover over the slots and you'll see what type of module it'll allow to be plugged in to it.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 17-01-2012, 15:13
frasnow's Avatar
frasnow frasnow is offline
Software
frasnow is a name known to allfrasnow is a name known to allfrasnow is a name known to allfrasnow is a name known to allfrasnow is a name known to allfrasnow is a name known to all
You might want to check your code. I don't know about LabVIEW, but in Java they changed the way you tell the software which module to use. Instead of specifying the slot in the cRIO, a module number is used. More information can be found in my post here.
Unread 17-01-2012, 18:00
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
They moved the order of the modules this year due to the new 4-slot cRIO.
The new order for the 8-slot cRIO is:
  1. ANALOG
  2. DIGITAL
  3. SOLENOID
  4. EMPTY
  5. ANALOG 2
  6. DIGITAL 2
  7. SOLENOID 2
  8. EMPTY
Unread 17-01-2012, 22:43
Statelover210 Statelover210 is offline
FRC #0862
Statelover210 is an unknown quantity at this point
I'm having the same issue so I would appreciate it if you posted the solution when u find it. Thanks.
Unread 17-01-2012, 23:06
Originally Posted by Ido_Wolf View Post
...Jaguars won't respond,...
Do you have power to the Digital Sidecar? Is the Robot Signal Light blinking as expected?
The Digital Sidecar should be connected by a 37-pin cable to a DIO module in slot 2 of the cRIO. What cable are you using? The ribbon cable that came in the Kit of Parts might have been assembled incorrectly; there are instructions here for checking and fixing it.
...we can't get image from the Axis Camera (model 206),...
Did you reconfigure the camera to the proper address? The 2012 Dashboard program expects it to be at 10.te.am.11 instead of last year's 192.168.0.90.
