Go to Post As Grandma used to say, "empirical data is better than no data at all." - dlavery [more]
Unread 17-01-2012, 23:24
bakerjohn42's Avatar
bakerjohn42 bakerjohn42 is offline
Team 3171 - Co-Captain
AKA: John Baker
FRC #3171 (Hurricane P.R.I.D.E.)
Team Role: Driver
bakerjohn42 is an unknown quantity at this point
Anyone able to track targets?
Has anyone had their robot track a target using a camera yet? if so, could you tell me what you called in your code to do so.
Unread 17-01-2012, 23:27
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Re: Anyone able to track targets?
I have. I threshold the image and get the particles analysis reports, and do some math on them to determine the location of any targets in the image (you need to first determine which ones are rectangles, then figure out their location). I changed a bunch of the WPILib code to suit my needs, but that's the basic idea. I hope sample code is released soon, so I can see how my results compare.
Unread 17-01-2012, 23:57
youxinche95 youxinche95 is offline
AKA: Eugene Che
FRC #0649 (MSET)
youxinche95 is an unknown quantity at this point
Correct, you getImage().thresholdHSL(bla,bla,bla,bla,bla,bla)
then you take that binary image and getParticles or something like that...
Those particles give you the essentially the loops.
NOTE! the threshold is set to the color of the color hoop, so the binaryimage will only be on if it fits those requirements.
Good luck!
Unread 18-01-2012, 00:09
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Yes, we have! In fact, there's a really good example on FIRST Forge to find reflective tape (or other?). It's one of the coolest thing's I've worked with to date, for sure. I couldn't be more excited about it.
Good luck!
Sidenote: You can get these "bla bla bla" arguments from the NI Vision Assistant. Simply run an HSL threshold over your image (after acquiring one, of course) and mess with the cool sliders until it's only seeing the tape.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 23-01-2012, 20:18
xmendude217 xmendude217 is offline
FRC #3851
xmendude217 is an unknown quantity at this point
what is supposed to be done to the image after it's processed?
Unread 23-01-2012, 22:42
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
We just got our robot tracking today, using the new sample.
Still gotta work on a good PID though; the robot is too eager to center on the target and goes crazy.
Also, with the camera overexposed (I think it's technically a very low exposure...), it likes to change colors on me every time it restarts. -_- So, for now, I keep having to adjust the color criteria. However, switching to HSL criteria, instead of RGB, helped significantly. The hue is very constant for the target.
Unread 29-01-2012, 01:42
sng sng is offline
FRC #0649
sng is an unknown quantity at this point
Does the cRio have enough horsepower to track the targets? We're finding it takes about a second to analyze each image, but maybe we are doing something wrong....
Unread 29-01-2012, 08:30
What is the resolution of the camera?
Greg McKaskle
