Go to Post Whenever we loose a committed member of FRC, our entire country pays the price. - daniel_dsouza [more]
Unread 18-01-2012, 00:38
CompSciGeek CompSciGeek is offline
FRC #0948
CompSciGeek is an unknown quantity at this point
Swerve Drive
So I'm a little confused. Our team, as far as I know, has almost never used swerve drive before. We are making the full omni type that has 8 motors(4 for drive, 4 for the angle) to allow for independent angles on each wheel.
EDIT: Never mind, I realize that my code actually never uses RobotDrive wow lol
Also, what's the default number of channels for every slot in a Jaguar?
Unread 18-01-2012, 00:41
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Swerve Drive
No. You write your own. And to be honest, I HIGHLY suggest that you start with getting a PID controller working with a wheel. Make that wheel get to a certain angle and stay there. Get that first then try getting the whole shebang.
Unread 18-01-2012, 00:44
FRC #0948
Re: Swerve Drive
Thanks, and I was also wondering the default number of channels there are on one slot for Jaguar/PWM/whatever
Unread 18-01-2012, 00:48
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Swerve Drive
The default slot of the Digital IO side car thing is slot 2 on the cRio. In software, you set it, there is no "default".
Unread 18-01-2012, 01:43
FRC #0948
Re: Swerve Drive
Thanks. Also another question:
So far, I have 8 Jaguars for drive and turn. I'm not sure if this is supposed to be an option, but is it supposed to be 4 Jaguars and 4 Servos?
Unread 18-01-2012, 02:05
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Swerve Drive
You can use a mix of Jaguars and Victors, but I don't think Servos will work, they don't have enough power to turn the gear box.
