Go to Post If you want to grow the program such that every student on the planet has the chance to participate, you have to start THINKING with a world-centric mindset. - Racer26 [more]
Unread 18-01-2012, 01:50
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Farthest Shot
Hey guys,
Today we were prototyping a shooter, and it turned out to be a little more powerful than expected . At ~80 feet I'm fairly sure this is the farthest anyone has ever launched this year's game piece:
http://www.youtube.com/watch?v=S6L1LLRHEFM
The contraption uses two kit wheels powered by a CIM geared UP at a ratio of 22:15. This set up is mirrored on the top and bottom (using a total of 4 wheels and 2 CIMs). The shooter takes ~1.5s to recover between balls. Back of napkin math suggests that the maximum surface velocity of the wheels is 200ft/s.
Hope you enjoyed that,
EDIT: When I say kit wheels, I mean 2011 kit.
- Alex
Unread 18-01-2012, 02:09
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Farthest Shot
Wow very cool
Just wondering how consistent was it? And how much compression did you use on the ball?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 18-01-2012, 02:17
lemiant's Avatar
the Dreamer
AKA: Alex
Re: Farthest Shot
Originally Posted by Mk.32 View Post
Wow very cool
Just wonder how consistent was it? And how much compression did you use on the ball?
It's not particularily consistent. While it probably stayed within ± 18" laterally, the shot varied almost 5 feet in distance.
We compress the ball significantly (not just in this one, but in all our good launcher prototypes), 3 inches is nothing out of the ordinary.
Unread 18-01-2012, 02:23
Mk.32's Avatar
AKA: Mark
Re: Farthest Shot
Any damage to the balls after that?
This kinda a shooter would make a good feeder bot.
Unread 18-01-2012, 08:09
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Re: Farthest Shot
Now you face the question that most teams are facing. Do you want to sacrifice two cim motors to use on your shooter?
Great distance, now just control the shot and you are golden!
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 18-01-2012, 09:19
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
Re: Farthest Shot
That's impressive, let's see you make a basket from that far.
-D
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
Unread 18-01-2012, 12:30
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: Farthest Shot
-D
For a basket from 80ft, the robot would need to shoot from the pits !!!
Unread 18-01-2012, 12:36
Ludicium Ludicium is offline
AKA: Bryan Flannery
FRC #0930 (Mukwonago B.E.A.R.s)
Ludicium is an unknown quantity at this point
Re: Farthest Shot
If you happened to do research on baseball pitching machines they compress baseballs usually around half there diameter, this is to counteract the slip high speed rollers tend to give.
Unread 18-01-2012, 13:10
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
Re: Farthest Shot
-D
Actually, if their inaccuracy scales linearly with distance, horizontal variation would be ~12in laterally, and 3 feet in distance. with appropriate backspin, I would estimate 1 in 4 would go in. Not bad!
Unread 18-01-2012, 13:52
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Farthest Shot
We tried the KOP wheels on a shooter from our lunacy bot using a 1:1 CIM drive and about 2 inch. of compression and it took BIG CHUNKS out of the balls. We went back to smooth wheels.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 18-01-2012, 15:15
AdamHeard's Avatar
Lead Mentor
Re: Farthest Shot
There are EIGHT motors in the kit that are comparable to a CIM in this application.
Sorry to call you out specifically, but I keep reading this on chief over and over.
Keep your 4 CIMs in drive, and use several of our your EIGHT 200+ W motors on our your shooter.
And after you've used 4 CIMs, and 8 200+ W motors, you still have 10 other weak to powerful motors for other systems.
FIRST has given us the most leniant KOP in history, motor allocation is trivial this year.
Unread 18-01-2012, 15:54
lemiant's Avatar
the Dreamer
AKA: Alex
Re: Farthest Shot
No significant damage (it does appear to smudge the lines on the balls). When I said kit wheels I was talking about the smooth ones from 2011
Unread 18-01-2012, 16:19
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Re: Farthest Shot
Agreed- I really don't know what all this fuss is about. CIMs are not jesus motors - they are powerful but the others are not far behind. For teams who are only using two CIMS on their drive- I am sure there are lots of teams who are reading these sort of posts and looking forward to ram-jamming your robots around the field while they go about collect balls. (I know I am) You would be better off running two banebot motors per side or a CIM and a fisherprice.... There are MANY combinations and some teams don't limit themselves to only four drive motors. The two teams I am mentoring are running 6.
Furthermore, why do you need to shoot 80ft? Sounds to me like you just threw reason to the wind and "Tim Taylor"ed your shooter.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 18-01-2012, 19:06
TheAthlete TheAthlete is offline
AKA: Adam Talajkowski
FRC #0930 (Mukwonago B.E.A.R.s - Building Extremely Awesome Robots)
Team Role: Electrical
TheAthlete is an unknown quantity at this point
Re: Farthest Shot
Hey guys,
- Alex
Last night we had our prototype launch the first shot a measured 100ft across the parking lot. After that it averaged a little less than 80, but was very inconsistent, probably because it was 10 degrees out and the basketballs were noticeably different in the cold. And the way we fed the ball into the launcher was inconsistent.
Our prototype was just a wood mock-up at a 45 angle with two cims directly attached to a single wheel(several years ago gray rubber wheels) aligned so they touch the largest circumference of the basketball, and spaced with a gap of about 4 inches for the ball to compress through. However, it did leave large black streaks across the ball, so...
It was definitely not what we were expecting, and not necessarily our goal to accomplish, but it was pretty darn neat.
For our actual design, we won't use cims, for a good reason as there is an extensive range of other motors, and we plan on using all 4 cims for drive train. And going toward a pitching machine like design, it will take some experimenting with compression to achieve a design that wont leave giant black marks during the match and actually fit in a reasonable range for the field. But overall, I think we know what path we're going down this season!
Unread 16-05-2012, 09:09
greasemonkey's Avatar
greasemonkey greasemonkey is offline
Truss me I'm a Doctor
AKA: Fred Parker, fredword, fredwardo, phred, frederick
FRC #3467 (windham windups)
greasemonkey is an unknown quantity at this point
Re: Farthest Shot
using a cim anywhere but on the drive train is a waste of torque that could be used on the drive train so i agree with you 100%
