Go to Post "Don't make me call my flying monkeys..." - Joe Johnson [more]
Unread 10-01-2012, 15:15
Spen.M.P.'s Avatar
Spen.M.P. Spen.M.P. is offline
FRC #3815 (Raider Robotics)
Spen.M.P. is an unknown quantity at this point
Windriver C++ VAC not found
When we tried to install the Windriver C++ it said that it needed a VAC, key, for it to work. Where can we find this key?
Unread 10-01-2012, 19:55
ssirovica's Avatar
ssirovica ssirovica is offline
Programming Captain
AKA: Sasha Sirovica
FRC #1458 (Red Ties)
ssirovica is an unknown quantity at this point
Re: Windriver C++ VAC not found
You can find the activation file for WindRiver on the installation CD, and the file is FirstRobotics_2012_install.txt.
Check out this link for more information.
Good Luck!
Computers run on smoke. When you let the smoke out the computer stops working.
Unread 12-01-2012, 20:47
Spen.M.P.'s Avatar
Thanks for the help! We found it right away.
Unread 13-01-2012, 21:11
Spen.M.P.'s Avatar
One more question, the files for FRC specifically did not install with it. The order we installed is first disc, second disc, applied update. Thanks for the help!
Unread 16-01-2012, 18:15
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
Post Re: Windriver C++ VAC not found
You need to do the updates too:
http://firstforge.wpi.edu/sf/frs/do/...2_update_for_c
After that, you should see the samples and the First menu context up top.
Unread 18-01-2012, 07:11
Spen.M.P.'s Avatar
We found the update on that page that we had missed at first, thanks for the help!
