Go to Post We're all human, we all make mistakes. How you deal with mistakes and problems, is what really elevates successful people, robotics teams, organizations, etc. above the rest. - artdutra04 [more]
Unread 18-01-2012, 08:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Help with Launcher
You want seemingly insane roller speeds to get good shots.
Squirrel has posted some really good videos and specs on his team's shooter. They're rocking about 4,000rpm axle speed with a single 8" wheel. That's about 42 m/s surface speed on their shooter.
Our shooter is substantially slower, around 6.4m/s and we're getting around 2.3m range with a high-arc shot (65deg from horizontal) with no roller slippage. This is about 70% of 'ideal'. Our range is very limited even though we have over twice the motor power of Squirrel's shooter. We are rebuilding our prototype for a much faster roller speed and using smaller, lighter, less powerful motors.
TL;DR notes:
-go for very fast roller speed
-ball-park 70% free speed for ideal trajectory calcs
-power/torque matters, but rollers/wheels will store lots of energy
Unread 18-01-2012, 19:01
Cem8301's Avatar
Cem8301 Cem8301 is offline
Carolyn
AKA: student president
FRC #3413 (Mad Cows)
Cem8301 is an unknown quantity at this point
Should that be in ft/sec?
The steaks are high. Prepare for udder destruction!! <3 Mad 3:O's
Unread 18-01-2012, 23:56
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Nope. meters/second
Check out this thread: http://www.chiefdelphi.com/forums/sh...hreadid=100540
If they're indeed running a CIM geared up 22:15 with a 6" kit wheel they're rocking about 190ft/s or about 58m/s tangential speed.
I would theorize that nearly all of the imparted energy from most roller/wheel shooter systems comes from the kinetic energy stored in the rotating mechanisms.
Unread 18-01-2012, 19:04
jeremy5561 jeremy5561 is offline
FRC #0919
jeremy5561 is an unknown quantity at this point
OK I'll talk to my team about using the planetary gearbox. We have more torque than we need.
Unread 18-01-2012, 19:42
FRC #0919
Ok well I made an excel spreadsheet to calculate this stuff and I figured that if we use the sprocket we're going to lost more speed, where if we use just the gearbox we could shoot at 10 m/s. Is there any way to directly connect the 8mm shaft to a wheel?
How would I attach two wheels to one axle and directly turn that axle from the output of the gearbox?
