Go to Post Having a spare arm that you can put on in 5 minutes or less intimidates the hardware into not breaking. - ChrisH [more]
Unread 18-01-2012, 09:03
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Re: Banebots RS-775 Case Short
We got our 4 Banebots 775's in last night and 3 out of the 4 have issues.
One motor had about 2M ohms of resistance between the terminals and the case. After running the motor for a about 5 minutes the motor must have cleared whatever debris was causing the reading.
The second motor read 13 ohms between the terminals and the case. We started by "zapping" the debris as was recommended last season to clear case shorts. After zapping the motors we had a 1M ohm resistance between the terminals and the case. We are still working with this motor to clear the debris causing the resistance.
The third motor was the best of them all. It had no case short and the resistance between terminals was good, but only one minor problem...the shaft doesn't spin at all. The motor is completely locked up.
I have a call into Banebots and will post their response to our issues.
I just hope other teams are having better luck with these motors then we are. The 775s are a nice motor when they are working properly.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
