Go to Post I've determined that the only thing rumors are good for is putting your knickers in a twist. - JaneYoung [more]
Unread 18-01-2012, 09:03
SenorZ's Avatar
SenorZ SenorZ is online now
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Determining ball speed, Vernier
My team has not built our shooter, but when we do I plan on using the Vernier Video Physics app to get some data on height, range, and speed. Has anyone done the same? If so, share experience, please.
http://www.vernier.com/products/software/video-physics/
Unread 18-01-2012, 11:35
hsekhon27 hsekhon27 is offline
FRC #0280 (TNT)
hsekhon27 is an unknown quantity at this point
Re: Determining ball speed, Vernier
If you're using the wheels for shooter, the formula for calculating the tangentional velocity (the velocity of the ball) is 2*pi*f*r, where f is frequency (number of rotations in 1 second) and r is radius of the ball. The formula for calculating the range is (v^2 sin2x)/g, where v is your speed (calculated by 2*pi*f*r), x is your launch angle, and g is 9.81. The formula for a height at a specific range r is r*tan(x)-(g*r)/(v*cos(x))^2. you can rearrange these formulas to find launch angles and launch velocities.
Unread 18-01-2012, 11:40
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
Taking some personal time
if your using 9.81 make sure your other measurements are metric as well. So your radius isn't 4 in its 0.1016 meters meters etc...
2012-2016 Wave Robotics Team 2826
Unread 18-01-2012, 12:35
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
I'm more than familiar with the theoretical speed, range, and height equations. I'm concerned with REAL flight patterns.
The app is an extension of the Vernier lab probe software. Its all about collecting a volume of data to interpret later.
If we get around to it today I'll post a link to the results.
Unread 18-01-2012, 21:56
aheg1220 aheg1220 is offline
FRC #0599
aheg1220 is on a distinguished road
We used that software in my physics class to confirm that the acceleration due to gravity is indeed 9.8 meters per second per second.
I think it'll work very well for gathering the data you need.
Unread 20-01-2012, 15:54
commonsense commonsense is offline
FRC #3452
commonsense will become famous soon enoughcommonsense will become famous soon enough
Because you are shooting a sphere all kinematic equations will work. However you may want some pro computing if you will be using back spin.
Unread 20-01-2012, 21:43
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
I have some experience as a physics teacher. The video analysis CAN work well. I don't know what level of precision you are looking for, but I would say if my team was looking to make a long range shooter I would use this tool. Use the best camera you can borrow and use good lighting. The more time you take in setting up your hardware, the better results you will get. Do an analysis of acceleration due to gravity to check how well your setup is.
