Go to Post And then the judges joined in and did the wave! - Basel A [more]
Unread 15-01-2012, 14:33
aeniug2's Avatar
aeniug2 aeniug2 is offline
AKA: Joseph
FRC #2879 ("Orange Thunder")
aeniug2 will become famous soon enoughaeniug2 will become famous soon enough
Windriver wont communicate with cRIO
My team recently switched to using C++. We understand C++ itself just fine, but we seem to be having terrible luck trying to set up WindRiver.
Whenever we try to set up communications between WindRiver and the cRIO, it appears as though it is working for a little while, and then we get this:
(sorry if the image is a tad big, I'm kinda new to this)
We have tried reinstalling WindRiver several times, we have tried fixing the error by doing what it says to (which is very complicated, and doesn't work)
Has anyone else seen this error before, or know how to fix it/what might be causing it?
Unread 15-01-2012, 19:43
Re: Windriver wont communicate with cRIO
Is your cRIO properly reformatted with the v43 image for C++ and configured for your team number (2879)? Is there a firewall blocking communication on the required port?
Unread 15-01-2012, 19:54
aeniug2's Avatar
AKA: Joseph
I made sure to allow everything through the firewall, and I thought we had Reimaged it correctly
But, just to be sure I tired re-imageing it again (just now, like, 30 seconds before your post appeared...)
I tried windriver again, and lo and behold it gives me an entirely new error:
any ideas?
Unread 15-01-2012, 19:59
any ideas?
That one I know. From the C++ Getting Started Guide (when you are on New Connection page in Wind River where you set the IP and kernel image):
Finally, click the “Select” button near the top right corner of the window. Click the “+” next to “MPC5xxx” to expand the choices. Select “MPC52xx” the click OK. Click “Finish” to create the connection.
Unread 15-01-2012, 20:04
aeniug2's Avatar
AKA: Joseph
OHHHHH MAI GHAWD!!! THANKS!!!
That fixes the connection... which should also fix the debugging and the deploying... (although, ye can never be too sure...)
Once again, THANKS!!!
now I can test all the code I wrote to occupy myself while I was waiting for help with this...
Unread 15-01-2012, 20:16
aeniug2's Avatar
AKA: Joseph
Ok... so...
Your suggestion DID fix the communications with the cRIO...
And when I run debug, I just get a "warning" about something insignificant.
But when I deployed the code, and tried out the DS, it says no robot code.
I read that I am supposed to deploy the .OUT file, but I couldn't find it in the folder that it builds to, so I assumed I should just try to use the MakeFile
(Ima guess that that is the wrong file to use)
where should I look to find the .OUT file?
EDIT: Never mind. I figured it out.
Unread 18-01-2012, 01:35
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
What did you figure out. We're dying to know, as the only thing we're seeing is a Make file as well. How did you get a .out file? (or where did you find it?)
Unread 18-01-2012, 09:08
aeniug2's Avatar
AKA: Joseph
Well... You head on over to the folder that has the Make file (names PNGGU8227 or something, you know what I mean...) Then there should be a folder named simpletemplate, then one named debug, just keep going that direction until you find "simpletemplate.out" (It will be named this no matter what your project is named).
Sorry if this isn't detailed enough, I'm kinda almost late for school, and my laptop took awhile to boot..
If you need a more detailed explanation, I'll be online again later in the day, or perhaps some of the other people on CD will help you out.
Hope this helped!
Unread 18-01-2012, 14:50
emusteve's Avatar
AKA: Steve Martin
#0470 (Alpha Omega)
>sigh<
Alas, no additional folder in with the make file. Our guess is that for some reason, the build never really completes. We can see the target, so don't really know what's going on. Guess we'll just have to hope we can contact Brad Miller to see if he has any advice. Very frustrating to be this far into the build with nothing to program with!
Thanks,
Steve
Unread 18-01-2012, 16:57
aeniug2's Avatar
AKA: Joseph
Hmm...I know what you mean about not being able to program anything... It kinda sucks.
Anyways, here is the exact path that I found our .OUT file under:
C:\WindRiver\Workspace\[project name]\PPC603gnu\SimpleTemplate\Debug\Simpletemplate.out
In terms of it not building fully, does it show any errors? or does it appear to have built successfully?
Unread 19-01-2012, 19:23
emusteve's Avatar
AKA: Steve Martin
#0470 (Alpha Omega)
Finally got one of the other machines to create a .out file, and tried to run that. Now I have another weird situation. Driver's station reports communication and code running, but nothing happens. I can see the battery voltage, but no PWM output. Tried running NetConsole and got the following output. Also tried putting in a printf, but got no output. So, I tried building the "Hello World" example program, and THAT doesn't even work!
Sooo tired of this!!
Unread 19-01-2012, 19:32
aeniug2's Avatar
AKA: Joseph
Wow... thats a tad odd... never seen anything like it, but then again I've only been using C++ for about 3 weeks now...
So... it builds without errors... but it doesn't do anything when its running on the robot? hmm...
Just gonna list a few simple things I've read about:
- Make sure you Undeploy the old code before deploying the new code...derp...
- When you formatted your cRIO, did it say all the modules were in the right spots?
- do you get errors in diagnostics area of the driver station at all? because I have had code that built fine, but still had "errors"
if it would help at all I could send ya my robot code (I doubt it would help, but I might as well offer, ya never know)
Unread 19-01-2012, 19:47
emusteve's Avatar
AKA: Steve Martin
#0470 (Alpha Omega)
Image deploys without a problem, Netconsole obviously is running fine, cRIO boots without reporting any errors.
We had tried running as deployed code, but same result. Undeploy and run in memory, we get this. Re-imaged to be sure NOTHING was resident, and tried running in memory. That's when I took the screen shot. Driver's station doesn't report any errors, says code is running, and reports battery voltage. That's all I get from it. (I did try enabling in both teleop and autonomous modes.)
Unread 19-01-2012, 19:51
Do you have a Digital Module present in slot 2? If so I would try re-imaging your cRIO.
Unread 19-01-2012, 20:21
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
Question Re: Windriver wont communicate with cRIO
Just an obvious question: Are you hitting enable?
