Go to Post Dance Dance Revolution is the only solution. That rhymed. I should not be on chief at this hour of the morning. >_< - Eugenia Gabrielov [more]
Unread 18-01-2012, 10:03
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Controlling the VEX 2-Wire Motor 393
First note that this is the about the 2012 legal motor, p/n 276-2177.
I would presume that this motor is controlled with this controller, but are there other options? i.e. Can this motor be controlled with a Victor 884 as well?
How does one step down the voltage from 12V to 7.2V that the motor is specc'ed for?
We have a spot that's perfect for this motor and I'd really like to use it since we have 100's of other VEX parts sitting around.
GitHub
Unread 18-01-2012, 12:51
Re: Controlling the VEX 2-Wire Motor 393
My assumption is that you'd run it like a servo (ie with the servo 6v jumper installed).
