Go to Post Sometimes an aggravating season is the most educational. - Al Skierkiewicz [more]
Unread 17-01-2012, 21:05
TimSchley's Avatar
TimSchley TimSchley is offline
AKA: Tim Schley
FRC #0997 (Spartan Robotics)
TimSchley is an unknown quantity at this point
Another issue with reimaging EO9 Classmate
I have followed all of the steps given from FIRST at http://www.usfirst.org/sites/default...ation_Rev0.pdf
When I try to boot from the flash drive, it goes through and runs fine, but when I restarted the computer afterward, it now says
"BOOTMGR is missing
Press Ctrl+Alt+Del to restart"
I looked and BOOTMGR is on the flash drive that I have been using to reimage the computer.
PLEASE HELP!!
Unread 18-01-2012, 09:38
Re: Another issue with reimaging EO9 Classmate
I've seen that happen to the restore stick when the DOS XCOPY wasn't done correctly.
So your Classmate boots from the new restore stick and successfully installs Windows?
Then when you later restart the Classmate without the restore stick, the Classmate can't find the Boot manager?
Unread 18-01-2012, 12:46
TimSchley's Avatar
AKA: Tim Schley
In trying to reimage again, I noticed that it didn't fully reimage. I will try to do the DOS xcopy again and see if that fixes it.
Unread 26-01-2012, 21:05
TimSchley's Avatar
AKA: Tim Schley
After several more tries, the re-imaging process keeps getting stopped during the "imagex" stage, around 26% complete. I still get "BOOTMGR is missing" error when trying to boot the computer.
Unread 26-01-2012, 23:01
rsisk's Avatar
rsisk rsisk is online now
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Put your USB stick in the USB hub, then the USB hub in the computer and try again.
I have found repeatedly that the USB stick just doesn't make a great connection to the Classmate.
The views expressed are mine and should not be construed to represent the views of anyone else.
