Go to Post There are a lot of great teams that impress me, but four that really stand out... Our team doesn't want to beat these teams, we want to be these teams. - Mark Holschuh [more]
Unread 18-01-2012, 12:05
Mr. Rogers's Avatar
Mr. Rogers Mr. Rogers is offline
That? That was in the CAD.
FRC #3539 (Byting Bulldogs)
Mr. Rogers will become famous soon enoughMr. Rogers will become famous soon enough
How fast can KOP encoders count?
We wanted to track the live rpm of our ball shooter shaft, turns about 5500 rpm max, could a 250 or 360 count encoder count that fast? (198000 counts per minute) (33000 counts a second) (using a 360 count.) Anybody know where we could find a single count encoder wheel (1 count per rev.), or could the software keep up at 33000 counts a second?
Grow the roses of success!
2011 Archimedes 2nd seed,
2011 Waterford Champion, 2011 Troy Simi-Finalist,
2011 Waterford Rookie all star, 2011 Troy Rookie all star
http://www.bytingbulldogs.com/
Unread 18-01-2012, 12:10
AdamHeard's Avatar
Lead Mentor
Re: How fast can KOP encoders count?
The encoder itself should have an rpm rating, but that's usually more of a mechanical issue then electrical.
The true limit on encoder counts is the cRIO.
I don't know the official upper limit, but Austin Schuh on 254/971 has quoted me that a 64 count encoder on a CIM 1:1 (5300 rpm) works. This is ~5600 counts/second.
For velocity control at such speeds, you really don't need that many ticks per second.
A single "tick" encoder could be made with various forms of light sensors, hall effect sensors, etc...
Unread 18-01-2012, 12:17
Mr. Rogers's Avatar
Sweet! Anybody know where I could find a 64 count or less encoder?
Unread 18-01-2012, 12:22
AdamHeard's Avatar
Lead Mentor
In this case I think a hall effect or light sensor packaged right is a much cheaper option with plenty of accuracy.
A light sensor can be made into such a sensor by merely making the surface of your wheel an encoder disk of sorts. For example, if your shooter wheel is white/light colored, put 1-2 lines of black electrical tape on it. If it's black, do the opposite.
Far, far cheaper. You'd wire it as a single phase (not quadrature) encoder and just set the ticks per rotation to 1-2 (whatever you install on it).
Unread 18-01-2012, 12:25
On the NI FIRST community, Joe Hershberger said the limit is 39,987 counts per second. https://decibel.ni.com/content/message/12523 All of this is handled by the FPGA, so there is no additional processor load as you increase the count rate.
Joe made one important caveat, that there is a perfect 90 degree phase relationship between the signals from the encoder. This isn't true with a real world encoder. I would leave 50-100% margin and only use a range of 30-20k counts per second.
Unread 18-01-2012, 12:29
We used a motor as an analog tachometer, instead of an encoder, the last time we did this.
Unread 18-01-2012, 12:50
Mark -
Could you (have one of your students) submit a CD whitepaper on this?
I'd be very interested to hear their thoughts on it and see the exact setup.
Unread 18-01-2012, 12:57
Originally Posted by EricVanWyk View Post
Mark -
Here's the whitepaper that was done at the time:
http://www.team358.org/files/electri...Tachometer.pdf
It never made it to CD whitepaper posting for some reason...
It's still working. We were using it the other night.
Unread 18-01-2012, 14:02
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
The E4P-360 encoder is good for 10,000 RPM. I agree you dont need that many pulses for speed control, but mechanically it is the simplest to use since we are using the CIMple gearbox. We intend to hook the encoder to a Jaguar for speed control (dont know the limit but we will find out if it works).
You could use a simple LED/Photodiode pair with the spokes of the wheel to break the beam. Should be very reliable and assuming 6 spokes, gives you 6 pulses/rev.
Unread 18-01-2012, 14:16
Thanks! One of my favorite lessons for electrical teams is the relationship between current and torque, voltage and speed.
As a side note the analog inputs can handle +/- 10V, so you could loosen the resistor divider, ditch D1 and replace D2 with something bi-directional.
Unread 18-01-2012, 14:40
Since you don't need direction for this application, if you used just one channel from the encoder (physically disabled the other channel in the cable), would the FPGA processing still work? And would that help make the allowable speed higher?
