Go to Post Are yellow cards still being given out like AOL demo CDs in the late 90s? - Billfred [more]
Unread 14-01-2012, 15:48
nlucido nlucido is offline
FRC #2838 (Eaglebots)
nlucido is an unknown quantity at this point
Re: FRC 2012 Kit of Parts and Field
Is there anyway that you can edit the parts after you import them into autodesk?
Unread 17-01-2012, 14:06
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Yes. Open the file and in the browser, find the Body entry. Right-click and select Edit Solid. The options are limited compared to a native Inventor part, but it may be enough for what you want.
Let me know how you get on and we can work on one part to let you see the work flow.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 17-01-2012, 17:44
scree0114 scree0114 is offline
FRC #3642 (Huskies)
scree0114 is an unknown quantity at this point
Allowed to use parts from mcmaster.com for the robot?
Unread 18-01-2012, 13:11
Yes, you can. For future reference, what parts do you need and should I include them in future KOP's?
Phil Dollan
Autodesk Inc.
Unread 18-01-2012, 15:38
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
I didn't see it when I downloaded the kit a couple of day ago, but how about the CRIO II now that all the rookie teams and a lot of vets are using it.
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
Unread 18-01-2012, 18:36
Jacob,
The CRIO part number CTF040V8 is located in the Control Systems section of the Kit of Parts. The Inventor part number is Control System_Sauro_CTF040V8.iam
If you have problems locating it, or if you are referring to another part, please let me know and I will resolve the issue for you.
Phil Dollan
Autodesk Inc.
Unread 18-01-2012, 18:40
Jacob,
I just realized that you are referring to a different part from cRio. Let me check again and I will update by tomorrow morning.
Phil Dollan
Autodesk Inc.
Unread 18-01-2012, 19:29
Jacob,
Jacob,
I was looking at the wrong part number, it should be Control System_NI_cRIO-FRC-II.ipt. It is located in the Control System area.
The modules 9201, 9403, and 9472 are also located in the Control Systems area.
Phil Dollan
Autodesk Inc.
Unread 18-01-2012, 19:44
FRC reunion tour
FRC #0079 (Krunch)
Jacob,
Thanks a lot
Unread 20-01-2012, 07:08
mryeagle mryeagle is offline
AKA: Jeff Yeagle
FRC #2229 (ROBOSHOP)
mryeagle is an unknown quantity at this point
Sounds like you are using Autodesk Inventor 2011. The 2012 KOP files cannot be opened in 2011.
so.. essentially any team thats not up to the latest and greatest version of autodesk is automatically at a disadvantage..
high tech, low down.
http://lh3.ggpht.com/_u-f_SuDRS8E/SjhtxflFZNI/AAAAAAAAArA/wNWwcr2dOWI/s144/DSC00472.JPG
Unread 20-01-2012, 21:27
The Autodesk KOP is available in 2012, 2011, and 2010 format, so any team should be in good shape for the majority of the parts.
If a new part is added for 2012 (and there are), then the work flow is as follows:
1. Open the new part in 2012 (it is available free to all FIRST teams) and save as a STEP file. You can now import into 2011 and older.
2. If you are stuck I can help you with some of the major new parts.
3. Some of the new parts are available on vendor websites as STEP files. Check AndyMark and others.
At Autodesk we are aware that some teams cannot update their software each year and hopefully my response will assure you are not at any disadvantage. Please contact me directly if you have any concerns.
phil.dollan@autodesk.com
Phil Dollan
Autodesk Inc.
