Go to Post "git er done" but do it right. - CJO [more]
Unread 16-01-2012, 02:01
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
Angry vxworks remote system connection w/ crio II
I'm having problems with remote system connection to the new frc II controller.
Here is the screen:
If I leave the server as "(default from target)".
I get this error:
So I go ahead and specify 5200B as a processor because 5125 is not in the list.
5200B is the older 8 port controller.
This gets me over that error but then I get this error:
It seems the latest winriver, after being updated, shows 6.3 and the crio shows 6.8.
Here is the connections screen:
I have applied all the updates I can find. I also went to preferences > Remote Systems to see if there is a 6.8 to make available, but nothing.
Any thoughts or info?
Unread 18-01-2012, 15:01
enrique's Avatar
Re: vxworks remote system connection w/ crio II
I guess its just me then.
Have you imaged your cRIO with v43?
Unread 18-01-2012, 15:45
enrique's Avatar
Yes, In fact the problem here is the crio has a higher version than the winriver vxworks. So if anything I think I'm missing an update for winriver.
The last update I did is the WorkbenchUpdate20120108rev2993.exe
Unread 18-01-2012, 15:56
enrique's Avatar
I also did the FRC2012Utilities.zip update on
http://joule.ni.com/nidu/cds/view/p/id/2262
And FRC2012DriverStationUpdate.zip on
http://joule.ni.com/nidu/cds/view/p/id/2263
Unread 18-01-2012, 15:57
You're reading the message backwards. Target (cRIO) is 6.3 as it should be. "Selected OS version" is 6.8. Now why you are getting this message is a good question as the only thing visible in the screenshot says 6.3
Unread 18-01-2012, 21:47
enrique's Avatar
Arrow Re: vxworks remote system connection w/ crio II
Under remote systems it says:
VxWorks 6.8:MPC5200B - MPC5200B
That's not on the crio?
Interesting that right above it it says target debugger 6.3. lol
I'm going to reformat it with v43 just in case.
Cause, I'm stumped.
Unread 19-01-2012, 01:20
enrique's Avatar
Smile Re: vxworks remote system connection w/ crio II
ok finally figured it out. Instead of MPC5200B for processor, I chose MPC5200 and it worked.
