Go to Post We had an autonomous bug last year . . . Funnily enough, this worked real well and other teams were asking us for this "feature." - dragoonex [more]
Unread 18-01-2012, 16:17
zombieslayer16 zombieslayer16 is offline
FRC #3460
zombieslayer16 is an unknown quantity at this point
Can I capture old program from last years robot?
I had formatted our team's netbook with the usb key First had sent, but I forgot to get the labview program off of it. Is there any way I can take last years robot and capture the program?
Unread 18-01-2012, 16:22
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: Can I capture old program from last years robot?
This has been discussed on here many times (although I'm having trouble getting you the link at the moment). The short answer is no.
- Alex
Unread 18-01-2012, 16:24
See this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=97990
Unread 18-01-2012, 16:36
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
You could FTP to the cRIO and get files. But you'd probably have to decompile it, which is not easy.
Unread 18-01-2012, 21:10
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
If all you want to do is transfer it to another CRIO, or to save a copy of it, you should be able to get it using FTP and then put it back on a CRIO, again using FTP.
Unfortunately, if you need the actual source code (to modify it, for example) there is no practical way to recover that information.
Unread 18-01-2012, 22:39
remulasce remulasce is offline
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
Only with Python.
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
Unread 19-01-2012, 09:10
You could get the source files from the cRIO only if they were stored there. It is possible to modify your build spec to include arbitrary data files or source files if you wish, but that isn't the default. This means that the files you would be uploading are the output of the compiler and not your source files.
Greg McKaskle
