Go to Post Set your goals as high as your team thinks they can achieve (drafted, drafting, win awards, regional champs, world champs, etc) and go for them. Let the chips fall and have no regrets. - BPetry234 [more]
Unread 18-01-2012, 15:33
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
pic: Magnetic arm concept.
Unread 18-01-2012, 15:38
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: pic: Magnetic arm concept.
Team update #4: alliances will receive 100 points for stacking robots red-blue-red-blue on the coopertition bridge.
Unread 18-01-2012, 15:44
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
Step #1 turn on magnet
Step #2 Connect Magnet to bridge
Step #3 Magnet to random robot passerby and put him on your head
Step #4 Magnet Kitteh bot on top of Steampipe bot
Step #5 ?????
Step #6 PROFIT
Unread 18-01-2012, 16:30
Gdeaver Gdeaver is offline
FRC #1640
No, The magnetic approach will not work for many reasons. However, what your looking for is a tractor beam like on star trek. Good old Mcmaster carr has one in stock that should fit in the FRC application and budget. It is part number 2643K1. Look into it.
Unread 18-01-2012, 16:42
Sean Raia's Avatar
Interesting idea. Il bring this up at tonights meating so we can mull it over. Thanks!
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
That's clearly a Dalek end effector, not a tractor beam. These are tractor beams. (Some are auto-resetting, heavy duty ones!)
Unread 18-01-2012, 18:12
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
wow cool they are only $7.35
looking at the picture and description I cant see how it works though...
Do you think this device will not break any rules?
http://images2.mcmaster.com/Contents...g?ver=18523693
__________________________________________________ _______
Another Idea I came up with is for a weightless way for making the extra energy you need to power those throwers. (yeah yeah yeah only the battery can store energy but It said nothing about energy production)
you may have heard of it before its the Buttered cat paradox
This idea is very light weight and effective.
It is based on the follow two theories:
Cats always land on their feet/Buttered toast always lands buttered side down.
we just need to tie some toast onto the back of a cat and stick on the robot while harvesting the rotational energy. here is some illistrations
and remember guys use real butter not margarine!
cole?
Unread 18-01-2012, 18:58
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
Can you imagine the amount of power needed to do that if it was an electro magnet!?!?! Its a good idea if it was a bit more realistic.
Unread 18-01-2012, 19:03
Team Role: Mascot
read the whole thread I came up to a solution for the energy problem did you not see it !?
cole?
Unread 18-01-2012, 19:14
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Too complicated and unreasonable!
I'd recommend you use The Force instead!
1058 PVC Pirates 2016 - xxxx
Unread 18-01-2012, 19:20
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
How do you suppose to get the robots to balance on top of you once you get them up there?
And wouldn't 298 lbs of robot crush you measly 149 lbs?
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 18-01-2012, 22:13
Sean Raia's Avatar
Mill the chassis out of a solid block of Aluminum, to retain maximum strength.
Unread 18-01-2012, 22:20
FRC #4084
****** magnets. How do they work?
Unread 18-01-2012, 22:49
dtengineering's Avatar
AKA: Jason Brett
This is a great idea, although I'd suggest using an extremely rare earth aluminum magnet.
Jason
Unread 18-01-2012, 23:24
Team Role: Mascot
I don't want the force if i can't use force lightning, violates r36
cole?
