Go to Post Do I think the bar is too high? I think impossible dreams and lofty goals are a key part of FIRST; the "top" being extremely far away only pushes people farther. - Chris is me [more]
Unread 18-01-2012, 14:24
kitsume13's Avatar
kitsume13 kitsume13 is offline
The Ginger
FRC #2152 (S*M*A*S*H)
kitsume13 is an unknown quantity at this point
Built Bridge Problems
(Didn't see any threads that already covered this)
So, Our team had Just finished a bridge to test on and we ran into a balance problem.
Our bridge's center of balance is off and we cannot find out what is wrong.
We built the bridge according to the low expense blueprints, it's made out of plywood, it can hold the required weight, but balance still off.
Has Anyone else had this problem? If so, how did you guys fix it?
Thanks!
-Rachel
Proud member of First Team 2152 S*M*A*S*H!
2012 South Florida Regional Imagery Award
2013 South Florida Regional Creativity Award
2013 Panther Prowl Finalist (team captain)
2013 Panther Prowl Judges Award
2013 Robocon: Tampa bay Awesome Pit Award
Unread 18-01-2012, 14:28
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Built Bridge Problems
A bridge built out wood and based on the drawings that FIRST gave us does not give you the proper balance and properties. You need to add weight to the ends to make it performance like the one used on the game fields [which are metal].
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 18-01-2012, 14:33
kitsume13's Avatar
The Ginger
Originally Posted by Mk.32 View Post
The bridge [wooden] built out of the drawings that FIRST gave us does not give you the proper balance and properties. You need to add weight to the ends to make it performance like the one used on the game fields.
Ah, That explains it.
Thanks!
-Rachel
Unread 18-01-2012, 14:40
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Our bridge is more sensitive to balance than the values given. So, this means we need to really calibrate our balance code to a finer level.
Good, we like it like that!
Unread 18-01-2012, 14:53
kitsume13's Avatar
The Ginger
Interesting, Did you follow the same blueprints as we did?
-Rachel
Unread 18-01-2012, 16:23
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Our bridge passes the battery test... but only with 140 LBS of weights on the bottom!!!!!!
Unread 18-01-2012, 16:25
Mk.32's Avatar
AKA: Mark
Just wondering, what did you use as the weights?
Unread 18-01-2012, 16:30
RDX1466's Avatar
RDX1466 RDX1466 is offline
Honey Badger
AKA: Matt
FRC #1466 (Webb Robotics)
Team Role: Webmaster
RDX1466 is on a distinguished road
Hey guys,
Our bridge has a good center of balance, but it is too sensitive to tipping. Has anyone else had this problem? Does anybody have any ideas?
Thanks,
CancerKidSwag
Unread 18-01-2012, 16:33
lemiant's Avatar
the Dreamer
AKA: Alex
Plate weights, kind of like these: http://s00.wos.com.au/images/999760-5.jpg .
  • They are separated into 4 stacks, each with a 25lb weight and a 10lb weight.
  • Our machinist made shaft adapters with an od the matches the inside of each weight and an id, that matches a 1/2" bolt.
  • 4 bolts are somehow (I can't remember) attached to the underside of the bridge.
We slide the adapters into the weights and the weights onto the bolts, then put a nut on the end and voila. This way the bridge is properly weighted, but we can easily remove the weights, so that we don't have to carry a 200lb bridge everywhere.
lemiant's Avatar
the Dreamer
AKA: Alex
Originally Posted by CancerKidSwag View Post
Hey guys,
Thanks,
CancerKidSwag
Please read the thread, the answer is right in front of you.
Unread 18-01-2012, 16:51
RDX1466's Avatar
Honey Badger
AKA: Matt
Sorry, read this post earlier in the day and didn't notice the new posts
Unread 18-01-2012, 17:07
Chi Meson's Avatar
Chi Meson Chi Meson is offline
"Strange and Anti-charmed"
AKA: Brian Chidley
FRC #2168 (Aluminum Falcons)
Chi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud of
There's already a good thread on this:
http://www.chiefdelphi.com/forums/sh...d.php?t=100094
