Camera not responding
Our team is attempting to use the Axis 206 camera, hopefully for tracking targets this year. We had issues last year with the camera repeatedly causing the robot to freeze up after a few seconds. At competition, the camera suddenly started working, so long as we called getInstance() ONCE only. We did not have time for vision tracking but were able to view the dashboard image. This year, even with the same code, the camera does not respond whatsoever. The robot overloads with error messages such as the following:
[cRIO] >>>>ERROR: S_errno_EHOSTDOWN (0x00000043): Failed to connect to the camera ...in CreateCameraSocket() in C:/WindRiver/workspace/WPILib/Vision/AxisCameraParams.cpp at line 457 We are using 2012 utilities, 2012 cRIO firmware, the camera was configured with the 2012 utility to connect through cRIO port 2 (on the 8-slot cRIO), the camera is receiving appropriate voltage, and the camera works just fine when connected directly to the Classmate. Using example code from 2010 for tracking, the program supposedly gets "100 images in x seconds", without errors until running for a few seconds. Nothing ever appears on the dashboard. Google found one or two teams that had similar errors (difference being "EHOSTDOWN"/error-code), but no solutions. Any ideas? Last edited by nickpeq : 18-01-2012 at 17:21. |
Re: Camera not responding
Camera should not be connected to cRIO port 2.
Connect it directly to your router instead. You should be able to ping it from your driverstation using ping 10.xx.yy.11 |
Also, we have had the same error when connected through the router, however I haven't tested this as extensively. If you have advice on using the router (should it start working on router only) for vision tracking, preferably without the involvement of LabView, I would still be grateful for that as well. Last edited by nickpeq : 18-01-2012 at 17:25. |
We had the same error after updating everything last week. But I commented out camera for the time being since we were working on something else at that time. But since this is the same problem as far as I remember, just wanted to let you know that you're not alone. Hopefully someone knows how to fix it - that will save us some time tomorrow since we plan on working on target tracking tomorrow.
For the record, we don't seem to have a C:/WindRiver directory.
This could be a "doh" moment, but hopefully(?) it's just a generic error message. |
Last year, the camera was also kept on the 192.168.x.x domain, which has also changed. The 2012 setup utility will change the IP address to 10.xx.yy.11. Even though the camera is connected through the router, the cRIO will still be able to capture images from it using the same WPILib functions as last year. We are running vision code on our 2012 cRIO in this manner. Hooking it up this way will also improve your driverstation video feed, and reduce load on your cRIO. The cRIO is no longer running a video server that relays the images from the camera to the driver station. Your driverstation can now retrieve video directly from the camera. |
#7
Were having this problem too. The WinRiver directory is created when you install WindRiver. Though when i tried to set Wind River up WPILib was not there. Has anyone set it up that could point us in the right direction as to how to get the library?
#8
Will try this tomorrow ![]() |
#9
Same.
Thank you very much Mr Lim! |
#10
We had the same error also when we plugged it into the 2nd port on our C-RIO. On the documentation on the Axis Camera code it says I should work if you plug it in that slot, we are using the old bridge connection for our prototype, is there a way to fix that error?
#11
In posts mentioned above, I believe support for the camera on port 2 has changed this year. There are also reasons as to why the other approach will likely work better for you. I strongly recommend you move the camera off port 2, run the camera setup utility, and patch it directly into the router instead. |
#12
Another cause of this error is caused by the setup utility - Greg (of NI) confirmed that there was a problem with the camera setup utility that causes errors such as this. Set up the camera manually. Reset the camera by holding the button on the back and follow these steps:
1) Connect to the camera at http://192.168.0.90 (your ip address will need to be on the same domain) 2) The camera will ask you to create a root password - "admin" will work. 3) Log into the camera with root:admin 4) Using the setup page, add the user FRC, password FRC as admin. 5) If you're planning on using the Smart Dashboard, enable anonymous viewing 6) Change the IP address of the camera to 10.te.am.11 Once you save that last setting, you will not be able to connect to the camera. It should be set up at this point. |
#13
#14
Lim if you read the FRC Getting Started with the 2012 FRC Control System it states the below:
I have had the camera working in both port 2 or the switch. As my team is unsure which way we will go for processing the image. Laptop/cRIO as they all have pro and con. |
#15
AxisCamera camera = AxisCamera.getInstance("192.168.0.90");
