Go to Post Welcome to CD, side effects aren't limited too, but may include, addiction to mechanical and electrical assemblies, desire to program in C, drawing objects in Solidworks and subconscious learning! - Jay H 237 [more]
Unread 18-01-2012, 17:30
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Problems Activating 3ds Max
I'm a mentor on Team 3489. For the past week we've been struggling to install and activate 5 licenses of 3ds Max.
When we try to download the software it say something like "You will now be issues a serial number" but we never see it. We've tried Windows XP & Vista, IE6, IE8 and Firefox.
How can we activate 3ds Max?
Unread 18-01-2012, 17:38
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Problems Activating 3ds Max
This is a quote from my hand out that I give the students for downloading Inventor, but the process is exactly the same for 3DS Max. It should give you a serial number and product code on the screen, which you enter in to the installation wizard. Activation occurs the first time you run the program, you click "activate" on the window that pops up, then you have to log in (with a separate account) and voila! you software is activated!
1. Make sure your computer can handle the software (refer to the provided table)
2. students.autodesk.com > “Register”
3. Enter all required information
4. You will receive a confirmation email. Click the link to create account
5. Return to students.autodesk.com > “Login”
6. Go to “Free Software” tab at top of page. Select “Autodesk Inventor Professional 2012”
7. Select appropriate Version, Language and OS then agree to terms in pop up window
8. Record Serial Number and Product Key > “Download”
9. WARNING! The file is large (3.3gb) Depending on your internet connection, it could take up to 2 hours.
10. When the download completes, run the file. The extractor will automatically run and upon completion will begin the installer. Follow Autodesk’s excellent on screen step by step installation directions.
11. Install only what is recommended.
12. Be sure the content library is selected for install, and when prompted to, select to install all of the contend libraries
13. When the install is complete, run the program for the first time and follow the directions to register the software. You will be asked to log in, you must create a new account on this page, the username and password you created earlier in the process will not work here. Unless of course you have licensed software in previous years.
EDIT: I also saw your looking for 5 licenses, each account on the student community is good for one activation. Each computer that you indent to install and activate on needs its own account (and serial number and product code)
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 18-01-2012, 20:15
AKA: Kevin Thorp
Yes, I'm familiar with the registration process. I'm trying to figure out why we don't see the serial number and product key after the website tells us it will display them.
I suppose it's some sort of security software installed in our computer lab.
The other problem is private email services are blocked at work, so the students can't check their email to verify their registration, and forget when they get home. I can work around this.
Unread 18-01-2012, 21:22
AKA: Scott
Oh okay, I was just making sure, that's odd, I've never had a problem...either way, in for an answer!
